Interpreting an API response
Contributors dmp-netapp
Each API request generates a response back to the client. You should examine the response to determine whether it was successful and retrieve additional data as needed.
HTTP status code
The HTTP status codes used by the ONTAP REST API are described below.
Code Reason phrase Description
200
OK
Indicates success for calls that do not create a new object.
201
Created
An object is successfully created. The location header in the response includes the unique identifier for the object.
202
Accepted
A background job has been started to perform the request, but has not completed yet.
400
Bad request
The request input is not recognized or is inappropriate.
401
Unauthorized
User authentication has failed.
403
Forbidden
Access is denied due to an authorization (RBAC) error.
404
Not found
The resource referred to in the request does not exist.
405
Method not allowed
The HTTP method in the request is not supported for the resource.
409
Conflict
An attempt to create an object failed because a different object must be created first or the requested object already exists.
500
Internal error
A general internal error occurred at the server.
Response headers
Several headers are included in the HTTP response generated by the ONTAP.
Location
When an object is created, the location header includes the complete URL to the new object including the unique identifier assigned to the object.
Content-type
This will normally be application/hal+json.
Response body
The content of the response body resulting from an API request differs based on the object, processing type, and the success or failure of the request. The response is always rendered in JSON.
  • Single object
    A single object can be returned with a set of fields based on the request. For example, you can use GET to retrieve selected properties of a cluster using the unique identifier.
  • Multiple objects
    Multiple objects from a resource collection can be returned. In all cases, there is a consistent format used, with num_records indicating the number of records and records containing an array of the object instances. For example, you can retrieve the nodes defined in a specific cluster.
  • Job object
    If an API call is processed asynchronously, a Job object is returned which anchors the background task. For example, the PATCH request used to update the cluster configuration is processed asynchronously and returns a Job object.
  • Error object
    If an error occurs, an Error object is always returned. For example, you will receive an error when attempting to change a field not defined for a cluster.
  • Empty JSON object
    In certain cases, no data is returned and the response body includes an empty JSON object.
HAL linking
The ONTAP REST API uses HAL as the mechanism to support Hypermedia as the Engine of Application State (HATEOAS). When an object or attribute is returned that identifies a specific resource, a HAL-encoded link is also included allowing you to easily locate and determine additional details about the resource.
Errors
If an error occurs, an error object is returned in the response body.
Format
An error object has the following format:
"error": {
"message": "<string>",
"code": <integer>[,
"target": "<string>"]
You can use the code value to determine the general error type or category, and the message to determine the specific error. When available, the target field includes the specific user input associated with the error.
Common error codes
The common error codes are described in the following table. Specific API calls can include additional error codes.
Code Description
1
409
An object with the same identifier already exists.
2
400
The value for a field has an invalid value or is missing, or an extra field was provided.
3
400
The operation is not supported.
4
405
An object with the specified identifier cannot be found.
6
403
Permission to perform the request is denied.
8
409
The resource is in use.
