Name services
Contributors dmp-netapp
You can use these API calls to manage the name services supported by ONTAP.
DDNS
You can display the Dynamic DNS (DDNS) information and manage the DDNS subsystem. This resource type is new with ONTAP 9.8.
DNS
DNS supports the integration of the ONTAP cluster in your network. This resource type was introduced with ONTAP 9.6.
LDAP
LDAP servers can be used to maintain user information. This resource type was introduced with ONTAP 9.6.
Name mappings
Name mappings allow you to map identities from one name domain to another. For example, you can map identities from CIFS to UNIX, Kerberos to UNIX, and UNIX to CIFS. This resource type was introduced with ONTAP 9.6.
NIS
NIS servers can be used to authenticate users and client workstations. This resource type was introduced with ONTAP 9.6.
