NetApp ONTAP Python client library
The ONTAP Python client library is a package you can install and use to write scripts that access the ONTAP REST API. It provides support for several underlying services, including connection management, asynchronous processing, exception handling, and error messages. By using the Python client library, you can quickly develop robust code to support the automation of ONTAP deployments.
NetApp maintains a GitHub repository containing code samples and other helpful information. You can navigate to the examples folder to access samples using the Python client library. |
Related links
