Object store
Contributors dmp-netapp Download PDF of this page
You can use these API calls to access S3-based object storage.
Buckets
A bucket is a container of objects and is structured using an object name space. Each S3 object server can have multiple buckets. This resource type was introduced with ONTAP 9.7 and updated with ONTAP 9.8.
Services
You can create and manage the ONTAP S3 configuration, including servers and bucket configurations. This resource type was introduced with ONTAP 9.7.
Service buckets
A bucket is a container of objects and is structured using an object name space. You can manage the buckets for a specific S3 server. This resource type was introduced with ONTAP 9.7.
S3 groups
You can create groups of S3 users and manage access control at the group level. This resource type is new with ONTAP 9.8.
S3 policies
You can create an S3 policy and associate it with a resource to define various permissions. This resource type is new with ONTAP 9.8.
Users
The S3 user accounts are maintained at the S3 server. User accounts are based on a pair of keys and associated with the buckets they control. This resource type was introduced with ONTAP 9.7.
