ONTAP REST API versioning
The REST API included with ONTAP 9 is assigned a version number. The API version number is independent of the ONTAP version number. You should be aware of the API version included with your release of ONTAP and how this might affect your use of the API.
The ONTAP system software contains versions of the REST API as follows:
- ONTAP 9.8
Version 1
- ONTAP 9.7
Version 1
- ONTAP 9.6
Version 1
Related links
