Preparing to use the Python client library
You should prepare the environment before using the Python client library.
Basic requirements
You must use Python 3.5 or later. In addition, the following packages are also required:
requests 2.22.1 or later
requests-toolbelt 0.9.1 or later
marshmallow 3.2.1 or later
Package name and version
The name of the Python client library package is netapp_ontap. The version associated with the package is a combination of the ONTAP major and minor version numbers the library was generated from, along with a minor version for the client within the ONTAP release. For example, valid version numbers include: 9.6.1, 9.6.2, and 9.7.1.
Installation
You must use pip to install the netapp_ontap package from the Python Package Index (PyPi) web site.
Documentation and additional resources
See the NetApp Developer Network for links to documentation and other resources.
