Learn about the NetApp Manageability SDK
The NetApp Manageability SDK provides a set of ONTAPI API calls for developing applications to monitor and manage your ONTAP storage. Together with the OnCommand Workflow Automation package, the SDK supports your efforts to automate the manage of your ONTAP systems.
While the NetApp Manageability SDK and OnCommand Workflow Automation continued to be supported, the ONTAP REST API is the preferred and strategic technology to use when automating your ONTAP systems. See Migrate from ONTAPI to the REST API for more information. |
You can download the NetApp Manageability SDK from the NetApp Support Site. The SDK supports several languages on the client side, including: Python, PowerShell, C, C++, Java, C#, VB.Net, and Ruby. Make sure to review the Interoperability Matrix Tool for information about the NetApp Manageability SDK and how it is supported with your version of ONTAP.
You can also use the API provided with the SDK to automate management tasks without writing any scripts. OnCommand Workflow Automation (OnCommand WFA) provides several prepackaged workflows to deploy and run the management tasks.
