Understanding the ONTAP REST API
Contributors dmp-netapp
Beginning with version 9.6, ONTAP includes a REST web services API. You can use the REST API to deploy and administer ONTAP storage resources. Before using the API, you should understand its design, architectural components, and limitations.
