Workflow 1: Updating the cluster contact and checking job state
Contributors dmp-netapp Download PDF of this page
This workflow updates the cluster contact information. Because the request is processed asynchronously, it also illustrates how to determine if the background job completes successfully.
1. Update the contact information for the cluster
You can issue an API call to update the contact information. Because the request runs asynchronously, you must confirm success of the associated job.
Category HTTP method Path
Cluster
PATCH
/cluster
Processing type
Asynchronous
Curl
curl -X PATCH -H 'Content-Type: application/json' -u admin:password -k -d @step01 'https://10.222.81.101/api/cluster'
  "contact": "support@company-demo.com"
JSON output
A job object with the associated identifier is returned.
{ "job": {
  "uuid": "d877f5bb-3aa7-11e9-b6c6-005056a78c89",
      "href": "/api/cluster/jobs/d877f5bb-3aa7-11e9-b6c6-005056a78c89"
2. Retrieve the status of the job
You must retrieve the state of the job to determine if the asynchronous request has completed successfully.
Cluster
GET
/cluster/jobs/{uuid}
Processing type
Synchronous
Curl
curl -X GET -H 'Content-Type: application/json' -u admin:password -k 'https:// 10.222.81.101/api/cluster/jobs/*uuid*'
Output
A job object with the state and other fields is returned.
  "description": "PATCH /api/cluster",
  "state": "success",
  "message": "success",
  "code": 0,
