ONTAP Foreign LUN Import
Perform ONTAP FLI AIX post-migration host remediation
Contributors netapp-barbe
After migration, AIX hosts require remediation steps to ensure the newly imported LUNs are properly recognized and functional.
Post-Migration - Offline FLI
For Offline FLI, bring the LUN online after deleting the lun import and confirming host initiators are connected.
Filesystem Block device LVM (FS) Cluster Sanboot
Step 1: Rescan storage on all the mapped AIX hosts
Step 1: Rescan storage on all the mapped AIX hosts.
Step 1: PowerON the server
Step 2: identify the multipath devices
Step 2: Verify the boot device list from the IPLInitial Program Load/SMS menu will list the new LUNs referencing the devices list coming from new Storage device. Set the boot order to the new device list path
Step 3: Check for the filesystem details
Step 3: Identify the multipath device ID and present it to the respective application.
Step 3: Ensure the new LUNs are discovered
Step 3: Ensure that the server boots up properly
Step 4: Mount the devices back to the respective folders
Step 4: Activate the VG
Step 4: verify the required cluster configuration and start the cluster application
Step 4: Restart the host to boot from newly mapped LUN that is part of LUN Import
Step 5: List down the LVs present on the VG
Step 5: Validate the cluster status and the application that is consuming.
Step 6: Mount the LVMs back to the respective folders
Note Refer to OS Vendor Documentation for Latest and updated command list.
Steps
  1. Rescan after detaching to confirm clean state.
    cfgmgr
  2. Identify storage devices.
    lsdev -Cc disk
    sanlun lun show all
    sanlun lun show all -pv
    lsmpio -l hdiskx
  3. Verify device is attached.
    lspv |grep hdiskx
  4. Identify the volume group and filesystems.
    lspv
    lsvg <vg_name>
    lsvg -l <vg_name>
    lsvg -p <vs_name>
  5. Varyonvg and mount filesystems.
    varyonvg <vg_name>
    mount /mount_point
    df -g
Post-Migration - Online FLI
After deleting the import relationship, confirm the new LUN operates independently with UNMAP enabled. After deleting the LUN import, check if the LUN is set with -space-reserve disabled and -space-allocation enabled. If not, modify it accordingly.
Filesystem Block device LVM (FS) Sanboot
SCSI UNMAP is automatically enabled if the device is thin provisioned.
Steps
    cfgmgr
    lsdev -Cc disk
    sanlun lun show all
    lsmpio -l hdiskx
    lspv |grep hdiskx
  4. Verify UNMAP on the device:
    chfs -a reclaim=normal /mount_point
    lvmstat -v vg_name -r
AIX/PowerVM
Step 1
Capture host information.
Step 2
Unmount the filesystem.
Step 3
Take a backup of the VG.
Step 4
Deactivate the VG.
Step 5
Export the VG.
