ONTAP Foreign LUN Import
Perform ONTAP FLI ESXi post-migration host remediation
Contributors netapp-barbe
After migration, ESXi hosts require remediation steps to ensure the newly imported LUNs are properly recognized and functional.
Post migration - Offline FLI
For Offline FLI, bring the LUN online after deleting the lun import and confirming host initiators are connected.
VMs/VMDK RDM WFSC VMSC
Step 1: Rescan storage on all mapped ESXi hosts.
Step 2: List volume/device details to confirm filesystem details on the LUN.
Step 2: Identify new NAA IDs and add RDMs back to the respective VMs.
Step 3: Identify datastore details and mount datastores back to ESXi.
Step 3: Power on guest VMs and start applications.
Step 4: Identify datastore details and mount datastores back to ESXi.
Step 4: Power on guest VMs and start applications.
Step 5: identify the RDM disks used by the cluster and remap them to the WFSC cluster nodes using the same controller IDs and unit numbers (for example, SCSI1:0) to maintain consistency with the previous configuration.
Step 5: Power on guest VMs and start applications
Step 6: Power on guest VMs and start the cluster application.
Note Refer to OS Vendor Documentation for Latest and updated command list.
Rescan after detaching to confirm clean state
esxcli storage core adapter rescan --all
Exit maintenance mode after completion
esxcli system maintenanceMode set --enable false
Rescan storage on all ESXi hosts mapped to the LUN
List devices and filesystems to confirm LUN / filesystem details
esxcli storage core device list
esxcli storage filesystem list
Identify new NAA IDs if they changed post-migration
esxcli storage core device list | grep -i naa
Mount VMFS datastore(s) back to ESXi
esxcli storage filesystem mount -l <DATASTORE_NAME>
Verify datastore mount
Add RDM back to VM (done via vSphere UI)
CLI is typically not used; verify backend device visibility instead.
esxcli storage core device list -d <naa.ID>
Exit maintenance mode (if applicable)
Power on guest VMs
(VM power operations are typically done via vCenter, but verification can be done on the ESXi host)
vim-cmd vmsvc/getallvms
vim-cmd vmsvc/power.on <VMID>
Post migration - Online FLI
After deleting the import relationship, confirm the new LUN operates independently with CAW/UNMAP/XCOPY/WRITESAME enabled.
Revert VMFS locking mode to ATS-only by unmounting the datastore, setting ATS-only, then remounting. After deleting the LUN import, check if the LUN is set with -space-reserve disabled and -space-allocation enabled. If not, modify it accordingly.
VMs/VMDK RDM VMSC
Step 2: Shut down guest VMs gracefully.
Step 3: Unmount datastores planned for migration; if shared, unmount from all hosts.
Step 4: Check VMFS locking mode (ATS-only vs ATS+SCSI). If ATS-SCSI, change to ATS-Only
Step 5: Identify datastore details and mount datastores back to ESXi.
Step 5: Enable VM-HA / DRS and configure the required heartbeat disks if required.
Step 6: Power on guest VMs and start applications.
Step 7: Validate datastore locking mode and VM/application health
Power on guest VMs
(VM power operations are typically done via vCenter, # but verification can be done on the ESXi host)
If ATS+SCSI is detected, convert to ATS-only
vmkfstools --configATSOnly 1 /vmfs/volumes/<DATASTORE_NAME>
