ONTAP Foreign LUN Import
Perform ONTAP FLI HP-UX post-migration host remediation
Contributors netapp-barbe
After migration, HP-UX hosts require remediation steps to ensure the newly imported LUNs are properly recognized and functional.
Post-Migration - Offline FLI
For offline FLI, bring the LUN online after deleting the lun import and confirming host initiators are connected.
Filesystem Block device LVM (FS) Cluster Sanboot
Step 1: Rescan storage on all the mapped HP-UX hosts
Step 1: Rescan storage on all the mapped HP-UX hosts.
Step 1: PowerON the server
Step 2: identify the multipath devices
Step 2: From the UEFI shell, verify the device mapping table and boot into hpux from the new Storage device. Set the primary boot device to new Storage LUN
Step 3: Check for the filesystem details
Step 3: Identify the multipath device ID and present it to the respective application.
Step 3: Ensure the new LVM device files are discovered properly
Step 3: Restart the host to boot from newly mapped LUN that is part of LUN Import
Step 4: Mount the devices back to the respective folders
Step 4: Import the VG/LVM
Step 4: verify the required cluster configuration and start the cluster application
Step 5: Activate the VG
Step 5: Validate the cluster status and the apllication that is consuming.
Step 6: List down the LVs present on the VG
Step 7: Mount the LVMs back to the respective folders
Post-Migration - Online FLI
After deleting the LUN import, check if the LUN is set with -space-reserve disabled and -space-allocation enabled. If not, modify it accordingly.
For SCSI UNMAP feature to operate correctly, please consult the Vendor documentation to verify the supported software versions. Veritas VxVM + VxFS combination is required to enable this feature.
Filesystem Block device LVM (FS) Sanboot
Steps
  1. Identify storage devices.
    ioscan -fnC disk
    insf -e
    sanlun lun show all
    sanlun lun show all -pv
    sanlun lun show -wwpn
  2. Import VG and Online the VG.
    vgimport /dev/vg_name /dev/disk/disk_name
    vgchange -a y /dev/vg_name
  3. Identify the volume group and filesystems.
    vgdisplay -v /dev/vg_name
    vgdisplay /dev/vg_name
    lvdisplay /dev/vg_name/lv_name
  4. Mount the filesystem.
    bdf
    mount /dev/vg_name/vol_name /mount_point
HP-UX
Step 1
Capture host information.
Step 2
Unmount the filesystem.
Step 3
Take a backup of the VG.
Step 4
Deactivate the VG.
Step 5
Export the VG.
