ONTAP Foreign LUN Import
Perform ONTAP FLI Solaris post-migration host remediation
Contributors netapp-barbe
After migration, Solaris hosts require remediation steps to ensure the newly imported LUNs are properly recognized and functional.
Post-Migration - Offline FLI
For offline FLI, bring the LUN online after deleting the lun import and confirming host initiators are connected.
Filesystem Block device LVM (FS) Cluster Sanboot
Step 1: Rescan storage on all the mapped Solaris hosts
Step 1: Rescan storage on all the mapped Solaris hosts.
Step 1: PowerON the server
Step 2: identify the multipath devices
Step 2: On the SPARC server OBP, configure the new boot device that is presented to this Host HBA
Step 3: Check for the Pool details
Step 3: Identify the multipath device ID and present it to the respective application.
Step 3: check the pool status
Step 3: Check for the filesystem details
Step 3: Restart the host to boot from newly mapped LUN that is part of LUN Import
Step 4: Mount the devices back to the respective folders
Step 4: Import the Pool
Step 4: verify the required cluster configuration and start the cluster application
Step 5: List down the FS present on the Pool
Step 5: Validate the cluster status and the apllication that is consuming.
Step 6: Mount the FS back to the respective folders
Note Refer to OS Vendor Documentation for Latest and updated command list.
Steps
  1. Rescan after attaching.
    cfgadm -al
  2. Identify storage devices.
    format
    sanlun lun show all
    mpathadm list lu
    mpathadm show lu
  3. Verify device is attached.
    format |grep disk_id
  4. Import the zpool and FS will automatically mounted.
    zpool import zpool_name
    df -g (to ensure its unmounted)
Post-Migration - Online FLI
After deleting the LUN import, check if the LUN is set with -space-reserve disabled and -space-allocation enabled. If not, modify it accordingly.
Filesystem Block device LVM (FS) Sanboot
Steps
    cfgadm -al
    format
    sanlun lun show all
    mpathadm list lu
    mpathadm show lu
    `format |grep disk_id`
    df -g
Solaris
Step 1
Capture host information.
Step 2
Unmount the filesystem.
Step 3
Take a backup of the VG.
Step 4
Deactivate the VG.
Step 5
Export the VG.
