ONTAP Foreign LUN Import
ONTAP FLI Site Survey and Planning worksheet FAS Config tab
Contributors netapp-barbe
As part of your Site Survey and Planning worksheet, you should have a tab containing information on your FAS configuration.
The following is an example of how to set up your FAS Config tab.
Cluster Name Cluster Management IP Address Cluster Management Credentials Available ONTAP System Manager Host
IP Address
Network Ports
Node
Interface Name
Port type
Port speed
VLAN Name/ID
IFGRP
SVM Name Type Protocols Aggregate SVM Root Volume
SVM Volume Aggregate Size SAN
LUN Name
LUN Size
SVM Network Interfaces
SVM
Interface Name
Interface Role
IP address/Netmask
Home Node/Home Port
Failover Group
SVM FCP Target Ports
SVM
FCP Port Name
WWPN
WWNN
Home Node
Home Port
Node FCP Initiator Ports
Node Name
FCP Port Name
WWPN
WWN
Homer Node
Home Port
