Site Survey and Planning worksheet FAS Config tab
As part of your Site Survey and Planning worksheet, you should have a tab containing information on your FAS configuration.
The following is an example of how to set up your FAS Config tab.
| Cluster Name | Cluster Management IP Address | Cluster Management Credentials Available | ONTAP System Manager Host | |
IP Address |
| Network Ports | |||||
Node |
Interface Name |
Port type |
Port speed |
VLAN Name/ID |
IFGRP |
| SVM Name | Type | Protocols | Aggregate | SVM Root Volume |
| SVM | Volume | Aggregate | Size | SAN |
LUN Name |
LUN Size |
| SVM Network Interfaces | |||||
SVM |
Interface Name |
Interface Role |
IP address/Netmask |
Home Node/Home Port |
Failover Group |
| SVM FCP Target Ports | |||||
SVM |
FCP Port Name |
WWPN |
WWNN |
Home Node |
Home Port |
| Node FCP Initiator Ports | |||||
Node Name |
FCP Port Name |
WWPN |
WWN |
Homer Node |
Home Port |
