Verifying source LUNs on destination storage for offline FLI
As part of the offline Foreign LUN Import process, you must verify your source LUNs on your destination storage.
Verify the source LUNs and mapping from source storage to destination storage.
Log in to the ONTAP storage through SSH using admin user.
Change the mode to Advanced:
set -privilege advanced -
Enter
ywhen asked if you want to continue. -
Discover the source array on ONTAP. Wait for a few minutes and retry to detect the source array.
storage array showDataMig-cmode::*> storage array show Prefix Name Vendor Model Options -------- ---------------------------- -------- ---------------- ---------- HIT-1 HITACHI_DF600F_1 HITACHI DF600F
When the storage array is discovered for the first time, ONTAP might not show the array by discovering automatically. Use the following instructions to reset the switch port where ONTAP initiator ports are connected.
Verify the source array is discovered through all the initiator ports.
DataMig-cmode::*> storage array config show -array-name HITACHI_DF600F_1 LUN LUN Node Group Count Array Name Array Target Port Initiator ------------ ----- ----- ---------------------------- ----------------------- DataMig-cmode-01 0 1 HITACHI_DF600F_1 50060e801046b960 0a 50060e801046b964 0b 50060e801046b968 0a 50060e801046b96c 0b DataMig-cmode-02 0 1 HITACHI_DF600F_1 50060e801046b960 0a 50060e801046b964 0b 50060e801046b968 0a 50060e801046b96c 0b -
List the source LUNs mapped from Hitachi storage. Verify the disk properties and paths.
You should see the number of paths expected based on your cabling (at least two paths for each source controller). You should also check the event log after masking the array LUNs.
DataMig-cmode::*> storage disk show -array-name HITACHI_DF600F_1 -fields disk, serial-number, container-type, owner, path-lun-in-use-count, import-in-progress, is-foreign disk owner is-foreign container-type import-in-progress path-lun-in-use-count serial-number -------- ----- ---------- -------------- ------------------ --------------------- ------------- HIT-1.2 - false unassigned false 0,0,0,0,0,0,0,0 83017542001E HIT-1.3 - false unassigned false 0,0,0,0,0,0,0,0 83017542000E HIT-1.14 - false unassigned false 0,0,0,0,0,0,0,0 830175420019 3 entries were displayed. DataMig-cmode::*>
