ONTAP Mediator
Maintain the host OS for ONTAP Mediator
Contributors netapp-camdenc netapp-aoife
Ensure the host OS for ONTAP Mediator is maintained regularly to achieve optimal performance.
Reboot the host
Reboot the host only when clusters are healthy. Clusters cannot respond to failures while ONTAP Mediator is offline. Set a time for maintenance before you reboot.
ONTAP Mediator automatically resumes during a reboot and re-enters previously configured relationships with ONTAP clusters.
Host package updates
Update any library or yum package except the kernel. Reboot the host if required for changes to take effect. Schedule a service window before rebooting the host.
If you install the yum-utils package, use the needs-restarting command to detect if any package changes require a reboot.
Reboot after updating ONTAP Mediator dependencies because changes do not take immediate effect.
Upgrade the host OS kernel
SCST must be compiled for the kernel you are using. To update the OS, you need to schedule time for maintenance.
Before you begin
The following requirements apply when the SCST package is installed with ONTAP Mediator.
  • You can update all library packages except the kernel, but you might need to reboot to apply changes in ONTAP Mediator. Schedule downtime if you need to reboot.
  • You should keep the OS kernel up to date. Upgrade the kernel core to a supported version listed in the ONTAP Mediator version matrix. You must reboot the system, so plan a maintenance window for the outage.
    • Uninstall the SCST kernel module before you reboot, and then reinstall it afterwards.
    • Prepare a supported version of SCST to reinstall before you start the kernel OS upgrade.
Note If you installed ONTAP Mediator 1.12 or later with support for HTTPS only, the SCST package is not installed and the host OS kernel can be upgraded without affecting ONTAP Mediator. Refer to your host OS documentation for upgrade instructions.
Steps
Follow these steps to upgrade the host OS kernel.
Note Before upgrading the kernel, check that the OS and ONTAP Mediator version are compatible. For supported versions, see the OS support matrix.
  1. Stop ONTAP Mediator.
  2. Uninstall the SCST package, see Perform host maintenance. (SCST doesn't provide an upgrade mechanism.)
  3. Upgrade the OS, and reboot.
  4. Re-install the SCST package.
  5. Re-enable ONTAP Mediator.
Upgrading the VM kernel can cause compatibility issues with SCST modules. Manually uninstall and reinstall SCST.
Note If you installed ONTAP Mediator 1.12 or later with support for HTTPS only, the SCST package is not installed and you can skip this task.
Step 1: Uninstall SCST
To uninstall SCST, use the tar bundle for your ONTAP Mediator version.
Steps
  1. Download the appropriate SCST bundle (as shown in the following table) and extract it.
    For this version …​
    Use this tar bundle…​
    ONTAP Mediator 1.13
    scst-3.10.tar.gz
    ONTAP Mediator 1.12.1
    scst-3.10.tar.gz
    ONTAP Mediator 1.12
    scst-3.10.tar.gz
    ONTAP Mediator 1.11
    scst-3.9.tar.gz
    ONTAP Mediator 1.10
    scst-3.9.tar.gz
    ONTAP Mediator 1.9.1
    scst-3.8.0.tar.bz2
    ONTAP Mediator 1.9
    scst-3.8.0.tar.bz2
    ONTAP Mediator 1.8
    scst-3.8.0.tar.bz2
    ONTAP Mediator 1.7
    scst-3.7.0.tar.bz2
    ONTAP Mediator 1.6
    scst-3.7.0.tar.bz2
    ONTAP Mediator 1.5
    scst-3.6.0.tar.bz2
    ONTAP Mediator 1.4
    scst-3.6.0.tar.bz2
    ONTAP Mediator 1.3
    scst-3.5.0.tar.bz2
    ONTAP Mediator 1.1
    scst-3.4.0.tar.bz2
    ONTAP Mediator 1.0
    scst-3.3.0.tar.bz2
    1. Access the open source package from the SCST sourceforge downloads.
    2. Select Download released versions.
    3. Extract the bundle to your VM.
  2. Run the following uninstall commands in the scst directory:
    1. systemctl stop mediator-scst
    2. make scstadm_uninstall
    3. make iscsi_uninstall
    4. make usr_uninstall
    5. make scst_uninstall
    6. depmod
Step 2: Install SCST
To manually install SCST, you need the SCST tar bundle that is used for the installed version of ONTAP Mediator (see the SCST table).
About this task
  • Perform this step before you install the ONTAP Mediator. If the SCST version you're using is newer than the version bundled with the ONTAP Mediator installer, the installer skips this step.
  • In some scenarios, the default installation of SCST on the upgraded OS can fail because the upgraded OS requires a patch.
    Beginning with ONTAP Mediator 1.12.1, if the installation fails, you can use the SCST repair tool located in /usr/local/bin/mediator_repair_scst to repair the installation.
    If the upgraded OS requires a patch, the tool contains it for the version of SCST shipped within the ONTAP Mediator package. The mediator_repair_scst tool is a standalone tool that is separate from the main installer and is packaged inside the ONTAP Mediator tgz file. It does not affect the ONTAP Mediator installation or upgrade paths.
Steps
  1. Run the following install commands in the scst directory:
    1. make 2release
    2. make scst_install
    3. make usr_install
    4. make iscsi_install
    5. make scstadm_install
    6. depmod
      Note
      If you're performing a first-time installation and want to pre-install ONTAP Mediator, run the following command before continuing with the next step:
      mkdir -p /opt/netapp/lib/ontap_mediator/ontap_mediator/SCST_mod_keys
    7. cp scst/src/certs/scst_module_key.der /opt/netapp/lib/ontap_mediator/ontap_mediator/SCST_mod_keys/
    8. patch /etc/init.d/scst < /opt/netapp/lib/ontap_mediator/systemd/scst.patch
      Note If you pre-install SCST before ONTAP Mediator during a first-time installation, skip this step. The installer applies relevant SCST patches.
  2. Optionally, if Secure Boot is enabled, before you reboot, perform the following steps:
    1. Determine each file name for the scst_vdisk, scst, and iscsi_scst modules:
      [root@localhost ~]# modinfo -n scst_vdisk
      [root@localhost ~]# modinfo -n iscsi_scst
    2. Determine the kernel release:
      [root@localhost ~]# uname -r
    3. Sign each module file with the kernel:
      [root@localhost ~]# /usr/src/kernels/<KERNEL-RELEASE>/scripts/sign-file \sha256 \
      /opt/netapp/lib/ontap_mediator/ontap_mediator/SCST_mod_keys/scst_module_key.priv \
      /opt/netapp/lib/ontap_mediator/ontap_mediator/SCST_mod_keys/scst_module_key.der \
      _module-filename_
    4. Install the UEFI key with the firmware.
      Instructions for installing the UEFI key are located at:
      /opt/netapp/lib/ontap_mediator/ontap_mediator/SCST_mod_keys/README.module-signing
      The generated UEFI key is located at:
  3. Reboot the system:
    reboot
Host changes to the hostname or IP
About this task
  • Perform this task on the Linux host where you installed ONTAP Mediator.
  • Do this only if the self-signed certificates are no longer valid because the hostname or IP address changes after you install ONTAP Mediator.
  • After the temporary self-signed certificate has been replaced by a trusted third-party certificate, you do not use this task to regenerate a certificate. If you do not have a self-signed certificate, you cannot use this procedure.
Step
Create a temporary self-signed certificate for the current host:
  1. Restart ONTAP Mediator:
    ./make_self_signed_certs.sh overwrite
    [root@xyz000123456 ~]# cd /opt/netapp/lib/ontap_mediator/ontap_mediator/server_config
    [root@xyz000123456 server_config]# ./make_self_signed_certs.sh overwrite
    Adding Subject Alternative Names to the self-signed server certificate
    # OpenSSL example configuration file.
    Generating self-signed certificates
    Generating RSA private key, 4096 bit long modulus (2 primes)
    e is 65537 (0x010001)
    Generating a RSA private key
    writing new private key to 'ontap_mediator_server.key'
    Signature ok
    subject=C = US, ST = California, L = San Jose, O = "NetApp, Inc.", OU = ONTAP Core Software, CN = ONTAP Mediator, emailAddress = support@netapp.com
    Getting CA Private Key
    [root@xyz000123456 server_config]# systemctl restart ontap_mediator
