ONTAP Mediator
Regenerate a temporary self-signed certificate for the ONTAP Mediator host
Contributors netapp-aoife netapp-camdenc
Regenerate a temporary self-signed certificate for the current host when a hostname or IP address change invalidates the existing certificate.
Note This procedure is only supported on systems running ONTAP Mediator 1.7 or later.
About this task
  • Perform this task on the Linux host where you installed ONTAP Mediator.
  • You can perform this task only if the generated self-signed certificates have become obsolete due to changes to the hostname or IP address of the host after installing ONTAP Mediator.
  • After the temporary self-signed certificate has been replaced by a trusted third-party certificate, you do not use this task to regenerate a certificate. The absence of a self-signed certificate will cause this procedure to fail.
Step
To regenerate a new temporary self-signed certificate for the current host, perform the following step:
  1. Restart ONTAP Mediator:
    ./make_self_signed_certs.sh overwrite
    [root@xyz000123456 ~]# cd /opt/netapp/lib/ontap_mediator/ontap_mediator/server_config
    [root@xyz000123456 server_config]# ./make_self_signed_certs.sh overwrite
    Adding Subject Alternative Names to the self-signed server certificate
    # OpenSSL example configuration file.
    Generating self-signed certificates
    Generating RSA private key, 4096 bit long modulus (2 primes)
    e is 65537 (0x010001)
    Generating a RSA private key
    writing new private key to 'ontap_mediator_server.key'
    Signature ok
    subject=C = US, ST = California, L = San Jose, O = "NetApp, Inc.", OU = ONTAP Core Software, CN = ONTAP Mediator, emailAddress = support@netapp.com
    Getting CA Private Key
