ONTAP Mediator
Start and stop ONTAP Mediator
Contributors netapp-aoife netapp-camdenc
Stop or restart ONTAP Mediator and SCST when you need to maintain the host or re-enable the service.
Stop ONTAP Mediator
To stop ONTAP Mediator, perform the following steps:
Steps
  1. Stop ONTAP Mediator:
    systemctl stop ontap_mediator
  2. Stop SCST:
    Note Skip this step if you installed ONTAP Mediator with support for HTTPS only.
    systemctl stop mediator-scst
  3. Disable ONTAP Mediator and SCST:
    systemctl disable ontap_mediator mediator-scst
Start ONTAP Mediator
To re-enable ONTAP Mediator, perform the following steps:
Steps
  1. Enable ONTAP Mediator and SCST:
    systemctl enable ontap_mediator mediator-scst
  2. Start SCST:
    systemctl start mediator-scst
  3. Start ONTAP Mediator:
    systemctl start ontap_mediator
