ONTAP Mediator
Troubleshoot ONTAP Mediator certificate-related issues
Contributors netapp-camdenc netapp-aoife
Use these checks to verify certificate properties when troubleshooting certificate issues.
Verify certificate expiration
Use the following command to identify the certificate validity range.
ONTAP Mediator 1.9 and later
[root@mediator_host server_config]# openssl x509 -in intermediate.crt -text -noout
Certificate:
    Data:
        Validity
            Not Before: Feb 22 19:57:25 2024 GMT
            Not After : Feb 15 19:57:25 2029 GMT
ONTAP Mediator 1.8 and earlier
[root@mediator_host server_config]# openssl x509 -in ca.crt -text -noout
Certificate:
    Data:
        Validity
Verify X509v3 extensions in CA certification
Use the following command to verify the X509v3 extensions in the CA certification.
The properties defined within v3_ca in openssl_ca.cnf are displayed as X509v3 extensions in intermediate.crt.
[root@mediator_host server_config]# pwd
/opt/netapp/lib/ontap_mediator/ontap_mediator/server_config
[root@mediator_host server_config]# cat openssl_ca.cnf
[ v3_ca ]
subjectKeyIdentifier = hash
authorityKeyIdentifier = keyid:always,issuer
basicConstraints = critical, CA:true
keyUsage = critical, cRLSign, digitalSignature, keyCertSign
Certificate:
    Data:
        X509v3 extensions:
            X509v3 Subject Key Identifier:
                9F:06:FA:47:00:67:BA:B2:D4:82:70:38:B8:48:55:B5:24:DB:FC:27
            X509v3 Authority Key Identifier:
                keyid:9F:06:FA:47:00:67:BA:B2:D4:82:70:38:B8:48:55:B5:24:DB:FC:27
            X509v3 Basic Constraints: critical
                CA:TRUE
            X509v3 Key Usage: critical
                Digital Signature, Certificate Sign, CRL Sign
The properties defined within v3_ca in openssl_ca.cnf are displayed as X509v3 extensions in ca.crt.
[ v3_ca ]
Certificate:
    Data:
        X509v3 extensions:
                CA:TRUE
Verify X509v3 extensions in server certificate and subject Alt Names
The v3_req properties defined in the openssl_server.cnf configuration file are displayed as X509v3 extensions in the certificate.
In the following example, you can obtain the variables in the alt_names sections by running the commands hostname -A and hostname -I on the Linux VM on which ONTAP Mediator is installed.
Check with your network administrator for the correct values of the variables.
[root@mediator_host server_config]# cat openssl_server.cnf
[ v3_req ]
basicConstraints       = CA:false
extendedKeyUsage       = serverAuth
keyUsage               = keyEncipherment, dataEncipherment
subjectAltName         = @alt_names
[ alt_names ]
DNS.1 = abc.company.com
DNS.2 = abc-v6.company.com
IP.1 = 1.2.3.4
IP.2 = abcd:abcd:abcd:abcd:abcd:abcd
Certificate:
    Data:
        X509v3 extensions:
                CA:FALSE
            X509v3 Extended Key Usage:
                TLS Web Server Authentication
            X509v3 Key Usage:
                Key Encipherment, Data Encipherment
            X509v3 Subject Alternative Name:
                DNS:abc.company.com, DNS:abc-v6.company.com, IP Address:1.2.3.4, IP Address:abcd:abcd:abcd:abcd:abcd:abcd
[ v3_req ]
[ alt_names ]
IP.1 = 1.2.3.4
Certificate:
    Data:
        X509v3 extensions:
                CA:FALSE
            X509v3 Key Usage:
Verify that a private key matches with a certificate
You can verify whether a particular private key matches with a certificate.
Use the following OpenSSL commands on the key and certificate respectively.
[root@mediator_host server_config]# openssl rsa -noout -modulus -in intermediate.key | openssl md5
Enter pass phrase for intermediate.key:
(stdin)= 14c6b98b0c7c59012b1de89eee4a9dbc
[root@mediator_host server_config]# openssl x509 -noout -modulus -in intermediate.crt | openssl md5
[root@mediator_host server_config]# openssl rsa -noout -modulus -in ca.key | openssl md5
Enter pass phrase for ca.key:
[root@mediator_host server_config]# openssl x509 -noout -modulus -in ca.crt | openssl md5
If the -modulus attribute for both match, it indicates that the private key and certificate pair are compatible and can work with each other.
Verify that a server certificate is created from a particular CA certificate
You can use the following command to verify that the server certificate is created from a particular CA certificate.
[root@mediator_host server_config]# openssl verify -CAfile root_ca.crt --untrusted intermediate.crt ontap_mediator_server.crt
ontap_mediator_server.crt: OK
[root@mediator_host server_config]# openssl verify -CAfile ca.crt ontap_mediator_server.crt
If the Online Certificate Status Protocol (OCSP) validation is being used, use the command openssl-verify.
