Uninstall ONTAP Mediator
If necessary, uninstall ONTAP Mediator after disconnecting it from ONTAP.
Before you begin
You must disconnect ONTAP Mediator from ONTAP before removing it.
About this task
Perform this task on the Linux host where you installed ONTAP Mediator.
If you are unable to reach this command, you might need to run the command using the full path as shown in the following example:
/usr/local/bin/uninstall_ontap_mediator
Step
Uninstall ONTAP Mediator:
uninstall_ontap_mediator[root@mediator-host ~]# uninstall_ontap_mediator ONTAP Mediator: Self Extracting Uninstaller + Removing ONTAP Mediator. (Log: /tmp/ontap_mediator.GmRGdA/uninstall_ontap_mediator/remove.log) + Remove successful. [root@mediator-host ~]#
