Hot-adding storage to a MetroCluster FC configuration
Contributors netapp-ivanad ntap-bmegan Download PDF of this page
You can add storage to a MetroCluster FC configuration without bringing down the system. The procedure you use depends on the type of MetroCluster FC configuration and whether you are adding a single disk shelf to an existing stack or an entire stack.
