Transitioning from MetroCluster FC to MetroCluster IP configurations
Contributors netapp-martyh netapp-thomi NetAppZacharyWambold netapp-ranuk netapp-aherbin ntap-bmegan Download PDF of this page
After reviewing all requirements and preparing for the transition, you perform the transition procedure. You must perform each task in order, completing all steps in each task before moving to the next. You should not connect the new controllers or storage shelves to the existing configuration until directed.
