ONTAP ONTAPI-to-REST mapping
security-key-manager
external-restore-get-iter
Note: In ONTAP 9.8 and earlier releases, there is no REST API to restore key IDs from key management servers.
This ONTAPI call does not have an equivalent REST API call.
external-status-get-iter
GET /api/security/key-managers
Note: In ONTAP 9.8 and earlier releases, there is no REST API to return key management server status.
Usage: This ONTAPI call can be issued against Storage VM (SVM) management LIFs.
ONTAPI attribute REST attribute Comment
key-server
No REST Equivalent
key-server-status
No REST Equivalent
node
No REST Equivalent
vserver
No REST Equivalent
max-records
max_records
Specifies the maximum number of records to return before paging.
key-query-get-iter
GET /api/security/key-managers/{security_key_manager.uuid}/keys/{node.uuid}/key-ids
Note: The REST API is available in ONTAP 9.11 release and onwards. In ONTAP 9.10 and earlier releases, there is no REST API to return information about individual keys.
key-id
key-id
key-server
key-server
key-store
key-store
key-tag
key-tag
key-type
key-type
key-user
key-user
node
node-uuid
restored
restored
vserver
svm-name
max-records
max_records
security-key-manager-add
Note: The security-key-manager-add ONTAPI is deprecated as of ONTAP 9.6. This ONTAPI is replaced by security-key-manager-external-add-servers.
security-key-manager-add-iter
Note: The security-key-manager-add-iter ONTAPI is deprecated as of ONTAP 9.6. This ONTAPI is replaced by security-key-manager-external-add-servers.
security-key-manager-backup-get
Note: The security-key-manager-backup-get ONTAPI has been deprecated as of ONTAP 9.6. This ONTAPI has been replaced by security-key-manager-onboard-backup-get.
security-key-manager-config-get
Note: In ONTAP 9.8 and earlier releases, there is no REST API to retrieve key manager configuration options.
security-key-manager-config-modify
Note: In ONTAP 9.8 and earlier releases, there is no REST API to modify key manager configuration options.
security-key-manager-create-key
Note: The security-key-manager-create-key ONTAPI is deprecated as of ONTAP 9.6. This ONTAPI is replaced by security-key-manager-key-database-create-key. In ONTAP 9.8 and earlier releases, there is no REST API to create an authentication key.
security-key-manager-delete
Note: The security-key-manager-delete ONTAPI is deprecated as of ONTAP 9.6. This ONTAPI is replaced by security-key-manager-external-remove-servers.
security-key-manager-delete-iter
Note: The security-key-manager-delete-iter ONTAPI is deprecated as of ONTAP 9.6. This ONTAPI is replaced by security-key-manager-external-remove-servers.
POST /api/security/key-managers/{uuid}/key-servers
key-servers
server
When adding a single server, use the server REST API attribute. To add multiple key-servers, use records, which is an array of servers.
vserver
No REST Equivalent
When using a REST API to add key-servers, identify the key manager by the UUID in the path.
security-key-manager-external-disable
DELETE /api/security/key-managers/{uuid}
vserver
No REST Equivalent
When using a REST API to disable a key manager, identify the key manager by the UUID in the path.
security-key-manager-external-enable
client-cert
external.client_certificate
key-servers
external.servers
keyservers-are-clustered
external.servers.secondary_key_servers
In the REST API, if external.servers.secondary_key_servers is populated, then the key servers are clustered.
server-ca-certs
external.server_ca_certificates
vserver
svm
UUID of the SVM to add key-manager to. Not applicable if adding to Vserver.
security-key-manager-external-get
GET /api/security/key-managers/{uuid}/key-servers/{server}
client-cert
No REST Equivalent
info
No REST Equivalent
key-server
server
No REST Equivalent
server-ca-certs
No REST Equivalent
timeout
timeout
vserver
No REST Equivalent
UUID in the REST API identifies the key manager.
key-server
No REST Equivalent
ONTAPI attribute key-server is already described in this section.
security-key-manager-external-get-iter
client-cert
No REST Equivalent
info
No REST Equivalent
key-server
server
No REST Equivalent
server-ca-certs
No REST Equivalent
timeout
timeout
vserver
No REST Equivalent
UUID in the REST API path identifies the key manager.
max-records
max_records
security-key-manager-external-modify
PATCH /api/security/key-managers/{uuid}
client-cert
server-ca-certs
vserver
No REST Equivalent
UUID in the REST API path identifies the key manager to be updated.
security-key-manager-external-modify-server
PATCH /api/security/key-managers/{uuid}/key-servers/{server}
key-server
No REST Equivalent
UUID of the key server is in the REST API path.
password
password
secondary-servers
timeout
timeout
username
username
vserver
No REST Equivalent
UUID of the key manager to which the key server is associated is in the REST API path.
DELETE /api/security/key-managers/{uuid}/key-servers/{server}
key-servers
No REST Equivalent
UUID of the key-server to remove is in the REST API path.
vserver
No REST Equivalent
security-key-manager-get
Note: The security-key-manager-add ONTAPI is deprecated as of ONTAP 9.6. This ONTAPI is replaced by security-key-manager-external-get.
security-key-manager-get-iter
Note: The security-key-manager-add ONTAPI is deprecated as of ONTAP 9.6. This ONTAPI is replaced by security-key-manager-external-get..
Note: In ONTAP 9.8 and earlier releases, there is no REST API to create a key.
security-key-manager-key-database-delete-key
Note: In ONTAP 9.8 and earlier releases, there is no REST API to delete a key.
security-key-manager-key-migrate
POST /api/security/key-managers/{source.uuid}/migrate
from-vserver
No REST Equivalent
source.uuid in the REST API path specifies the from key-manager
to-vserver
uuid
uuid specifies the "to" key-manager
security-key-manager-key-store-get-iter
Note: In ONTAP 9.8 and earlier releases, there is no REST API to retrieve the key-store of each key manager. However, you can use the GET /api/security/key-managers REST API to get information about one or more key managers. Included in that information are the details about the key-store for each key manager.
vserver
No REST Equivalent
UUID in the REST API path identifies the key manager for which to retrieve the backup.
security-key-manager-onboard-disable
Usage: This ONTAPI call cannot be issued against Storage VM (SVM) management LIFs.
vserver
No REST Equivalent
UUID in the REST API path identifies the key manager to disable.
security-key-manager-onboard-enable
cc-mode-enabled
No REST Equivalent
okm-on-usb-enabled
No REST Equivalent
onboard-passphrase
onboard.passphrase
vserver
No REST Equivalent
security-key-manager-onboard-sync
passphrase
onboard.existing_passphrase
vserver
No REST Equivalent
UUID in the REST API path identifies the key manager to sync.
security-key-manager-onboard-update-passphrase
existing-passphrase
new-passphrase
onboard.passphrase
vserver
No REST Equivalent
UUID in the REST API path identifies the key manager to update.
security-key-manager-query-get
Note: The security-key-manager-query-get ONTAPI is deprecated. This ONTAPI is replaced by key-query-get-iter. In ONTAP 9.8 and earlier releases, there is no REST API to query individual keys.
security-key-manager-query-get-iter
Note: The security-key-manager-query-get-iter ONTAPI is deprecated. This ONTAPI is replaced by key-query-get-iter. In ONTAP 9.8 and earlier releases, there is currently no REST API to query individual keys.
security-key-manager-query-v2-get
Note: The security-key-manager-query-v2-get ONTAPI is deprecated as of ONTAP 9.6. This ONTAPI is replaced by key-query-get-iter. In ONTAP 9.8 and earlier releases, there is no REST API to query individual keys.
security-key-manager-query-v2-get-iter
Note: The security-key-manager-query-v2-get-iter ONTAPI is deprecated as of ONTAP 9.6. This ONTAPI is replaced by key-query-get-iter. In ONTAP 9.8 and earlier releases, there is no REST API to query individual keys.
security-key-manager-restore-get
Note: The security-key-manager-restore-get ONTAPI is deprecated. This ONTAPI is replaced by external-restore-get-iter. In ONTAP 9.8 and earlier releases, there is no REST API to restore key IDs from key management servers.
security-key-manager-restore-get-iter
security-key-manager-restore-v2-get
security-key-manager-restore-v2-get-iter
security-key-manager-volume-encryption-supported
Note: There is no REST API to determine if volume_encryption is supported. However, you can use the GET /api/security/key-managers REST API to get information about one or more key managers. Included in that information is whether volume_encryption is supported.
