Configure AIX 7.3/VIOS 4.x for FCP and iSCSI with ONTAP storage
The AIX Host Utilities software provides management and diagnostic tools for AIX hosts that are connected to ONTAP storage. When you install the AIX Host Utilities on an AIX 7.3/VIOS 4.x host, you can use the Host Utilities to help you manage FCP and iSCSI protocol operations with ONTAP LUNs.
Step 1: Optionally, enable SAN booting
You can configure your host to use SAN booting to simplify deployment and improve scalability. If your configuration doesn't support SAN booting, you can use a local boot.
SAN booting is the process of setting up a SAN-attached disk (a LUN) as a boot device for an AIX/PowerVM host host. You can set up a SAN boot LUN to work in a AIX Multipath I/O (MPIO) environment that is using the FC protocol and running AIX Host Utilities with either the FC or FCoE protocol. The method you use to create a SAN boot LUN and install a new OS image in an AIX MPIO environment depends on the protocol that you are using.
AIX requires that only one path be visible to a SAN boot disk until MPIO is enabled. Installing or migrating an AIX boot disk generally requires temporarily restricting the FC zoning for the host to include a single FC initiator and a single FC target. After you install the Host Utilities, including the PCM package, you can reboot the OS to fully enable MPIO. At that point, add the additional FC initiators and FC targets to the zone. Then, run cfgmgr -v and bosboot -a to update the boot configuration to include all available paths.
Use the Interoperability Matrix Tool to verify that your AIX OS, protocol, and ONTAP version support SAN booting.
Follow the best practices for setting up a SAN boot in the vendor documentation.
Perform a local boot by installing the AIX OS on the local hard disk, for example, on an SSD, SATA, or RAID.
Step 2: Install the AIX Host Utilities
NetApp strongly recommends installing the AIX Host Utilities to support ONTAP LUN management and assist technical support with gathering configuration data. The MPIO package from the Host Utilities provides MPIO support for AIX and VIOS.
Installing the AIX Host Utilities provides additional timeout settings on your AIX host. |
Step 3: Confirm the multipath configuration for your host
You can use multipathing with AIX and PowerVM to manage ONTAP LUNs.
Multipathing allows you to configure multiple network paths between the host and storage system. If one path fails, traffic continues with the remaining paths. The AIX and PowerVM environments of the Host Utilities use the AIXs native multipathing solution (MPIO).
The Path Control Module (PCM) is responsible for controlling multiple paths for an AIX host. The PCM is a storage vendor supplied code that handles path management and is installed and enabled during the Host Utilities installation.
To ensure that multipathing is configured correctly for your host, verify that you have the NetApp recommended settings configured for your ONTAP LUNs.
Verify that "MPIO NetApp" is available. "MPIO NetApp" is loaded during the AIX Host Utilities installation and becomes available after you reboot the host.
lsdev -Cc diskExample outputhdisk1 Available 00-00-02 MPIO NetApp FCP Default PCM Disk -
The AIX Host Utilities load the following parameter settings for ONTAP LUNs.
Show parameter settings
Parameter Environment Value for AIX Note algorithm
MPIO
round_robin
Set by Host Utilities
hcheck_cmd
MPIO
inquiry
hcheck_interval
MPIO
30
hcheck_mode
MPIO
nonactive
lun_reset_spt
MPIO / non-MPIO
yes
max_transfer
MPIO / non-MPIO
FC LUNs: 0x100000 bytes
qfull_dly
MPIO / non-MPIO
2-second delay
queue_depth
MPIO / non-MPIO
64
reserve_policy
MPIO / non-MPIO
no_reserve
re_timeout (disk)
MPIO / non-MPIO
30 seconds
Uses OS Default values
dyntrk
MPIO / non-MPIO
Yes
fc_err_recov
MPIO / non-MPIO
Fast_fail
q_type
MPIO / non-MPIO
simple
num_cmd_elems
MPIO / non-MPIO
1024 for AIX
3072 for VIOSFC EN1B, FC EN1C
num_cmd_elems
MPIO / non-MPIO
1024 for AIX
FC EN0G
Configure the following settings to optimize I/O operations for FC.
Parameter AIX versions AIX OS default value NetApp recommended value rw_timeout (disk)
AIX 7.3TL3
NPIV:30 seconds, vSCSI:45 seconds
NPIV:30 seconds, vSCSI:120 seconds
AIX 7.2TL5
VIOS 3.1
30 seconds
30 seconds
VIOS 4.1
30 seconds
30 seconds
Configure the following settings to optimize I/O operations for iSCSI.
AIX 7.3TL3
vSCSI:45 seconds
vSCSI:120 seconds
AIX 7.2TL5
vSCSI:45 seconds
vSCSI:120 seconds
VIOS 3.1
120 seconds
30 seconds
VIOS 4.1
120 seconds
30 seconds
All AIX7.2 and AIX 7.3 standalone
120 seconds
30 seconds
isw_err_recov (iscsi0)
delayed_fail
fast_fail
If your storage configuration includes MetroCluster or SnapMirror active sync, change the default settings:
MetroClusterBy default, the AIX OS enforces a shorter I/O timeout when there are no available paths to a LUN. This might occur in configurations that include single-switch SAN fabric and in MetroCluster configurations that experience unplanned failovers. For additional information and recommended changes to default settings, see the Knowledge Base article What are AIX Host support considerations in a MetroCluster configuration?.
SnapMirror active syncSnapMirror active sync is supported for an AIX host. The support behavior differs by ONTAP release:
Beginning with ONTAP 9.19.1, SnapMirror active sync is supported in Active/Active configuration, enabling non-disruptive SnapMirror active sync operations. See the Knowledge Base article SnapMirror active sync support for AIX: behavior by ONTAP release and migration guidance.
For ONTAP 9.11.1 to 9.18.1, SnapMirror active sync is supported in Active/Standby configuration. See the Knowledge Base article How to configure an AIX host for SnapMirror active sync in ONTAP 9.11.1 to 9.18.1.
Verify the parameter settings and that multiple paths are listed for an ONTAP LUN:
lsmpioIn the following example for an AFF or FAS system, the PCM is listed for NetApp.
Show example
# lsmpio -l hdisk1 name path_id status path_status parent connection hdisk1 0 Enabled Non fscsi6 203200a098ba7afe,5b000000000000 hdisk1 1 Enabled Non fscsi8 203100a098ba7afe,5b000000000000 hdisk1 2 Enabled Sel,Opt fscsi6 203000a098ba7afe,5b000000000000 hdisk1 3 Enabled Sel,Opt fscsi8 203800a098ba7afe,5b000000000000 # lsattr -El hdisk1 PCM PCM/friend/NetAppDefaultPCM Path Control Module False PR_key_value 0x6d0000000002 Persistant Reserve Key Value True algorithm round_robin Algorithm True clr_q no Device CLEARS its Queue on error True dist_err_pcnt 0 Distributed Error Sample Time True dist_tw_width 50 Distributed Error Sample Time True hcheck_cmd inquiry Health Check Command True hcheck_interval 30 Health Check Interval True hcheck_mode nonactive Health Check Mode True location Location Label True lun_id 0x5b000000000000 Logical Unit Number ID False lun_reset_spt yes LUN Level Reset True max_transfer 0x100000 Maximum TRANSFER Size True node_name 0x204800a098ba7afe FC Node Name False pvid none Physical volume identifier False q_err yes Use QERR bit True q_type simple Queuing TYPE True qfull_dly 2 Delay in seconds for SCSI TASK SET FULL True queue_depth 64 Queue DEPTH True reassign_to 120 REASSIGN time out value True reserve_policy PR_shared Reserve Policy True rw_timeout 30 READ/WRITE time out value True scsi_id 0xec409 SCSI ID False start_timeout 60 START unit time out value True timeout_policy fail_path Active/Passive Disk Path Control Module True ww_name 0x203200a098ba7afe FC World Wide Name False
Verify the path status for ONTAP LUNs:
sanlun lun showThe following example outputs show the correct path status for ONTAP LUNs in an ASA, AFF, or FAS configuration.
ASA configurationsAn ASA configuration optimizes all paths to a given LUN, keeping them active ("primary"). This improves performance by serving I/O operations through all paths at the same time.
Show example
# sanlun lun show -p |grep -p hdisk78 ONTAP Path: vs_aix_clus:/vol/chataix_205p2_vol_en_1_7/jfs_205p2_lun_en LUN: 37 LUN Size: 15g Host Device: hdisk78 Mode: C Multipath Provider: AIX Native Multipathing Algorithm: round_robin ------ ------- ------ ------- --------- ---------- host vserver AIX AIX MPIO path path MPIO host vserver path state type path adapter LIF priority ------ ------- ------ ------- --------- ---------- up primary path0 fcs0 fc_aix_1 1 up primary path1 fcs0 fc_aix_2 1 up primary path2 fcs1 fc_aix_3 1 up primary path3 fcs1 fc_aix_4 1AFF or FAS configurationAn AFF or FAS configuration should have two groups of paths with higher and lower priorities. Higher priority Active/Optimized paths are served by the controller where the aggregate is located. Lower priority paths are active but non-optimized because they are served by a different controller. Non-optimized paths are only used when optimized paths aren’t available.
The following example displays the correct output for an ONTAP LUN with two Active/Optimized ("primary") paths and two Active/Non-Optimized ("secondary") paths:
Show example
# sanlun lun show -p |grep -p hdisk78 ONTAP Path: vs_aix_clus:/vol/chataix_205p2_vol_en_1_7/jfs_205p2_lun_en LUN: 37 LUN Size: 15g Host Device: hdisk78 Mode: C Multipath Provider: AIX Native Multipathing Algorithm: round_robin ------- ---------- ------ ------- ---------- ---------- host vserver AIX AIX MPIO path path MPIO host vserver path state type path adapter LIF priority ------- ---------- ------ ------- ---------- ---------- up secondary path0 fcs0 fc_aix_1 1 up primary path1 fcs0 fc_aix_2 1 up primary path2 fcs1 fc_aix_3 1 up secondary path3 fcs1 fc_aix_4 1
Step 4: Review the known issues
There are no known issues.
