Configure Citrix XenServer 9.0 for FCP and iSCSI with ONTAP storage
Configure Citrix XenServer 9.0 for multipathing and with specific parameters and settings for FCP and iSCSI protocol operations with ONTAP storage.
The Linux Host Utilities software package doesn't support Citrix XenServer operating systems. |
Step 1: Optionally, enable SAN booting
You can configure your host to use SAN booting to simplify deployment and improve scalability.
Use the Interoperability Matrix Tool to verify that your Linux OS, host bus adapter (HBA), HBA firmware, HBA boot BIOS, and ONTAP version support SAN booting.
Enable SAN booting in the server BIOS for the ports to which the SAN boot LUN is mapped.
For information on how to enable the HBA BIOS, see your vendor-specific documentation.
Verify that the configuration was successful by rebooting the host and verifying that the OS is up and running.
Step 2: Confirm the multipath configuration for your host
You can use multipathing with Citrix XenServer 9.0 to manage ONTAP LUNs.
To ensure that multipathing is configured correctly for your host, verify that the /etc/multipath.conf file is defined and that you have the NetApp recommended settings configured for your ONTAP LUNs.
Locate the
/etc/multipath.conffile.If the reference
/etc/multipath.conffile doesn't have the NetApp device specific configuration parameters, add these parameters by using the following customized.conf drop-infile. You can find this file under/etc/multipath/conf.d/:Don't make changes to the /etc/multipath.conffile because the file contents might be overwritten during a system update.Show file contents
$sudo tee -a /etc/multipath/conf.d/custom.conf >/dev/null <<'EOF' defaults { polling_interval 5 } blacklist { wwid <Insert_LUN_wwid_string> devnode "^(ram|raw|loop|fd|md|dm-|sr|scd|st)[0-9]*" devnode "^hd[a-z]" devnode "^cciss.*" } devices { device { vendor "NETAPP" product "LUN.*" user_friendly_names no path_checker "tur" prio "ontap" detect_prio yes path_grouping_policy "group_by_prio" path_selector "service-time 0" failback immediate fast_io_fail_tmo 5 dev_loss_tmo infinity no_path_retry queue features "3 queue_if_no_path pg_init_retries 50" flush_on_last_del yes hardware_handler "0" retain_attached_hw_handler yes rr_weight uniform } } EOF -
The first time you configure multipathing, you might need to enable and start the multipath services to load the recommended settings:
systemctl enable multipathdsystemctl start multipathd -
Each time you boot the host, the
/etc/multipath/conf.d/custom.conffile automatically loads the NetApp recommended host multipath parameters as the default settings.The following table shows the native Linux OS compiled multipath parameter settings for ONTAP LUNs.
Show parameter settings
Parameter Setting detect_prio
yes
dev_loss_tmo
"infinity"
failback
immediate
fast_io_fail_tmo
5
features
flush_on_last_del
"yes"
hardware_handler
"0"
no_path_retry
queue
path_checker
"tur"
"group_by_prio"
path_selector
"service-time 0"
polling_interval
5
prio
"ontap"
product
LUN
yes
rr_weight
"uniform"
user_friendly_names
no
vendor
NETAPP
Verify the parameter settings and path status for your ONTAP LUNs:
multipath -llThe default multipath parameters support ASA, AFF, and FAS configurations. In these configurations, a single ONTAP LUN shouldn't require more than four paths. Having more than four paths can cause problems during a storage failure.
The following example outputs show the correct parameter settings and path status for ONTAP LUNs in an ASA, AFF, or FAS configuration.
ASA configurationAn ASA configuration optimizes all paths to a given LUN, keeping them active. This improves performance by serving I/O operations through all paths at the same time.
Show example
/usr/sbin/mpathutil status show topology create: 3600a098038315045572b5930646f4b63 dm-1 NETAPP ,LUN C-Mode size=9.0G features='4 queue_if_no_path pg_init_retries 50 retain_attached_hw_handle' hwhandler='1 alua' wp=rw `-+- policy='service-time 0' prio=50 status=active |- 15:0:0:0 sdb 8:16 active ready running |- 15:0:1:0 sdc 8:32 active ready running |- 16:0:0:0 sdcf 69:48 active ready running `- 16:0:1:0 sdcg 69:64 active ready running
AFF or FAS configurationAn AFF or FAS configuration should have two groups of paths with higher and lower priorities. Higher priority Active/Optimized paths are served by the controller where the aggregate is located. Lower priority paths are active but non-optimized because they are served by a different controller. Non-optimized paths are only used when optimized paths aren't available.
The following example displays the output for an ONTAP LUN with two Active/Optimized paths and two Active/Non-Optimized paths:
Show example
/usr/sbin/mpathutil status show topology create: 3600a098038315045572b5930646f4b63 dm-1 NETAPP ,LUN C-Mode size=9.0G features='4 queue_if_no_path pg_init_retries 50 retain_attached_hw_handle' hwhandler='1 alua' wp=rw |-+- policy='service-time 0' prio=50 status=active |- 15:0:0:0 sdb 8:16 active ready running `- 15:0:1:0 sdc 8:32 active ready running `-+- policy='service-time 0' prio=50 status=active |- 16:0:0:0 sdcf 69:48 active ready running `- 16:0:1:0 sdcg 69:64 active ready running
Step 3: Optionally, exclude a device from multipathing
If required, you can exclude a device from multipathing by adding the WWID for the unwanted device to the "blacklist" stanza for the /etc/multipath/conf.d/custom.conf file.
Determine the WWID:
/lib/udev/scsi_id -gud /dev/sda"sda" is the local SCSI disk that you want to add to the blacklist.
An example WWID is
360030057024d0730239134810c0cb833. -
Add the WWID to the "blacklist" stanza:
blacklist { wwid 360030057024d0730239134810c0cb833 devnode "^(ram|raw|loop|fd|md|dm-|sr|scd|st)[0-9]*" devnode "^hd[a-z]" devnode "^cciss.*" }
Step 4: Customize multipath parameters for ONTAP LUNs
If your host is connected to LUNs from other vendors and any of the multipath parameter settings are overridden, you need to correct them by either modifying an existing stanza or adding a new stanza in the /etc/multipath/conf.d/custom.conf file that applies specifically to ONTAP LUNs. You need to scroll down in the file to review the changes that apply to your host. If you don't correct the parameters, the ONTAP LUNs might not work as expected.
You shouldn't override the recommended parameter settings for ONTAP LUNs. These settings are required for optimal performance of your host configuration. Contact NetApp support, your OS vendor, or both for more information. |
The following example shows how to correct an overridden default. In this example, the custom.conf drop-in file defines values for path_checker and no_path_retry that aren't compatible with ONTAP LUNs, and you can't remove these parameters because ONTAP storage arrays are still attached to the host. Instead, you correct the values for path_checker and no_path_retry by adding a device stanza to the custom.conf drop-in file that applies specifically to the ONTAP LUNs.
Show example
defaults {
path_checker readsector0
no_path_retry fail
devices {
device {
vendor "NETAPP"
product "LUN"
no_path_retry queue
path_checker tur
Step 5: Review the known issues
There are no known issues.
