ONTAP SAN Host Utilities
Learn about the Linux Host Utilities "sanlun" utility for ONTAP storage
Contributors netapp-pcarriga
Linux Host Utilities is a NetApp host software that provides sanlun commands on your Linux host. The sanlun utility is installed automatically when you install the NetApp Host Utilities package. This utility provides the sanlun commands that you can use to manage ONTAP LUNs and host bus adapters (HBAs). The sanlun commands return information about the ONTAP LUNs mapped to your host, multipathing, and information necessary to create initiator groups.
In the following example, the sanlun lun show all command returns ONTAP LUN information:
controller(7mode/E-Series)/            device     host               lun
vserver(cDOT/FlashRay)   lun-pathname  filename   adapter  protocol  size    Product
data_vserver          /vol/vol1/lun1   /dev/sdb   host16   FCP       120.0g  cDOT
data_vserver          /vol/vol1/lun1   /dev/sdc   host15   FCP       120.0g  cDOT
data_vserver          /vol/vol2/lun2   /dev/sdd   host16   FCP       120.0g  cDOT
data_vserver          /vol/vol2/lun2   /dev/sde   host15   FCP       120.0g  cDOT
Note
  • For Linux Host Utilities 7.1, the "sanlun" utility is common across all configurations and protocols of the Host Utilities. As a result, some of its contents apply to one configuration, but not another. Having unused components doesn't affect your system performance.
  • The "sanlun" utility isn't supported for the following hypervisor types:
    8.0
    For Linux Host Utilities 8.0, the "sanlun" utility isn't supported for Citrix XenServer, Oracle VM, and Red Hat Enterprise Virtualization.
    7.1
    For Linux Host Utilities 7.1, the "sanlun" utility isn't supported for Citrix XenServer, Red hat Enterprise Virtualization, and Proxmox.
