ONTAP SAN Host Utilities
Configure Proxmox VE 8.x for FCP and iSCSI with ONTAP storage
Contributors netapp-pcarriga netapp-sarajane
Configure Proxmox VE 8.x for multipathing and with specific parameters and settings for FCP and iSCSI protocol operations with ONTAP storage.
FCP and iSCSI with Proxmox VE 8.x have the following known limitations:
  • The Linux Host Utilities do not support Proxmox VE 8.x operating systems.
  • The SAN boot configuration is not supported.
Step 1: Confirm the multipath configuration for your host
You can use multipathing with Proxmox VE 8.x to manage ONTAP LUNs.
To ensure that multipathing is configured correctly for your host, verify that the /etc/multipath.conf file is defined and that you have the NetApp recommended settings configured for your ONTAP LUNs.
Steps
  1. Verify that the /etc/multipath.conf file exits. If the file doesn't exist, create an empty, zero-byte file:
    touch /etc/multipath.conf
  2. The first time the multipath.conf file is created, you might need to enable and start the multipath services to load the recommended settings:
    systemctl enable multipathd
    systemctl start multipathd
  3. Each time you boot the host, the empty /etc/multipath.conf zero-byte file automatically loads the NetApp recommended host multipath parameters as the default settings. You shouldn't need to make changes to the /etc/multipath.conf file for your host because the operating system is compiled with the multipath parameters that recognize and manage ONTAP LUNs correctly.
    The following table shows the Linux OS native compiled multipath parameter settings for ONTAP LUNs.
    Show parameter settings
    Parameter Setting
    detect_prio
    yes
    dev_loss_tmo
    "infinity"
    failback
    immediate
    fast_io_fail_tmo
    5
    features
    "2 pg_init_retries 50"
    flush_on_last_del
    "always"
    hardware_handler
    "1"
    no_path_retry
    queue
    path_checker
    "tur"
    path_grouping_policy
    "group_by_prio"
    path_selector
    "service-time 0"
    polling_interval
    5
    prio
    "ontap"
    product
    LUN
    retain_attached_hw_handler
    yes
    rr_weight
    "uniform"
    user_friendly_names
    no
    vendor
    NETAPP
  4. Optionally, override the default value for the find_multipaths parameter to ensure that ONTAP LUNs are correctly discovered and managed by multipathd:
    1. Set find_multipaths to "no" in the defaults section of /etc/multipath.conf:
      defaults {
          find_multipaths "no"
    2. Reload the multipath service:
      systemctl reload multipathd
    Note By default, the Proxmox OS-native multipath configuration sets find_multipaths to "strict" with the empty zero byte /etc/multipath.conf configuration file each time you boot the host. This can prevent the host discovering newly presented ONTAP LUNs as multipath devices, which means they do not appear under multipath control automatically. Existing ONTAP LUNs remain discovered and under multipath control after each reboot.
  5. Verify the parameter settings and path status for your ONTAP LUNs:
    multipath -ll
    The default multipath parameters support ASA, AFF, and FAS configurations. In these configurations, a single ONTAP LUN shouldn't require more than four paths. If there are more than four paths, it might cause issues with the paths during a storage failure.
    The following example outputs show the correct parameter settings and path status for ONTAP LUNs in an ASA, AFF, or FAS configuration.
    ASA configuration
    An ASA configuration optimizes all paths to a given LUN, keeping them active. This improves performance by serving I/O operations through all paths at the same time.
    Show example
    multipath -ll
    3600a098038315071592b59713261566d dm-38 NETAPP,LUN C-Mode
    size=100G features='3 queue_if_no_path pg_init_retries 50' hwhandler='1 alua' wp=rw
    `-+- policy='service-time 0' prio=50 status=active
      |- 8:0:0:7 sdbv 68:144 active ready running
      |- 9:0:0:7 sdbx 68:176 active ready running
      |- 6:0:0:7 sdbr 68:80  active ready running
      `- 7:0:0:7 sdbt 68:112 active ready running
    AFF or FAS configuration
    An AFF or FAS configuration should have two groups of paths with higher and lower priorities. Higher priority Active/Optimized paths are served by the controller where the aggregate is located. Lower priority paths are active but non-optimized because they are served by a different controller. Non-optimized paths are only used when optimized paths aren’t available.
    The following example shows the output for an ONTAP LUN with two Active/Optimized paths and two Active/Non-Optimized paths:
    Show example
    multipath -ll
    3600a0980383149764b5d567257516273 dm-0 NETAPP,LUN C-Mode size=150G features='3 queue_if_no_path pg_init_retries 50' hwhandler='1 alua' wp=rw
    | |- 16:0:3:0  sdcg 69:64  active ready running
    | `- 10:0:0:0  sdb  8:16   active ready running
    `-+- policy='service-time 0' prio=10 status=enabled
      |- 10:0:1:0  sdc  8:32   active ready running
      `- 16:0:2:0  sdcf 69:48  active ready running
Step 2: Confirm the iSCSI configuration for your host
Ensure that iSCSI is configured correctly for your host.
About this task
You perform the following steps on the iSCSI host.
Steps
  1. Verify that the iSCSI initiator package (open-iscsi) is installed:
    $apt list |grep open-iscsi
    You should see an output similar to the following example:
    open-iscsi/noble-updates,noble-updates,now 2.1.9-3ubuntu5.4 amd64
  2. Verify the iSCSI initiator node name, which is located in the /etc/iscsi/initiatorname.iscsi file:
    InitiatorName=iqn.YYYY-MM.com.<vendor>:<host_name>
  3. Configure the iSCSI session timeout parameter located in the /etc/iscsi/iscsid.conf file:
    node.session.timeo.replacement_timeout = 5
    The iSCSI replacement_timeout parameter controls how long the iSCSI layer should wait for a timed-out path or session to reestablish itself before failing any commands on it. You should set the value of replacement_timeout to 5 in the iSCSI configuration file.
  4. Enable the iSCSI service:
    $systemctl enable iscsid
  5. Start the iSCSI service:
    $systemctl start iscsid
  6. Verify that the iSCSI service is running:
    $systemctl status iscsid
    Show example
    ●iscsid.service - iSCSI initiator daemon (iscsid)
         Loaded: loaded (/usr/lib/systemd/system/iscsid.service; enabled; preset: disabled)
         Active: active (running) since Mon 2026-01-12 12:53:18 IST; 2 days ago
    TriggeredBy: ● iscsid.socket
           Docs: man:iscsid(8)
       Main PID: 1127419 (iscsid)
          Tasks: 2 (limit: 76557)
         Memory: 4.3M (peak: 8.8M)
            CPU: 1.657s
         CGroup: /system.slice/iscsid.service
                 ├─1127418 /usr/sbin/iscsid
                 └─1127419 /usr/sbin/iscsid
  7. Discover the iSCSI targets:
    $iscsiadm --mode discovery --op update --type sendtargets --portal <target_IP>
    show example
    iscsiadm --mode discovery --op update --type sendtargets --portal 192.168.166.70
    192.168.166.70:3260,1042 iqn.1992-08.com.netapp:sn.c770be5d934811f0b624d039eac809ba:vs.5
    192.168.165.71:3260,1045 iqn.1992-08.com.netapp:sn.c770be5d934811f0b624d039eac809ba:vs.5
    192.168.165.70:3260,1044 iqn.1992-08.com.netapp:sn.c770be5d934811f0b624d039eac809ba:vs.5
    192.168.166.71:3260,1043 iqn.1992-08.com.netapp:sn.c770be5d934811f0b624d039eac809ba:vs.5
  8. Log in to the targets:
    $iscsiadm --mode node -l all
  9. Set iSCSI to log in automatically when the host boots:
    $iscsiadm --mode node -T <target_name> -p <ip:port> -o update -n node.startup -v automatic
    Replace <target_name> with the target name that you want to log in to automatically when the host boots. Replace <ip:port> with the IP address and port number of the target. For example:
    iscsiadm --mode node -T iqn.1992-08.com.netapp:sn.c770be5d934811f0b624d039eac809ba:vs.5 -p 192.168.166.70:3260 -o update -n node.startup -v automatic
  10. Verify the iSCSI sessions:
    $iscsiadm --mode session
    Show example
    tcp: [1] 192.168.166.71:3260,1043 iqn.1992-08.com.netapp:sn.c770be5d934811f0b624d039eac809ba:vs.5 (non-flash)
    tcp: [2] 192.168.165.71:3260,1045 iqn.1992-08.com.netapp:sn.c770be5d934811f0b624d039eac809ba:vs.5 (non-flash)
    tcp: [3] 192.168.165.70:3260,1044 iqn.1992-08.com.netapp:sn.c770be5d934811f0b624d039eac809ba:vs.5 (non-flash)
    tcp: [4] 192.168.166.70:3260,1042 iqn.1992-08.com.netapp:sn.c770be5d934811f0b624d039eac809ba:vs.5 (non-flash)
Step 3: Optionally, exclude a device from multipathing
If required, you can exclude a device from multipathing by adding the WWID for the unwanted device to the "blacklist" stanza for the multipath.conf file.
Steps
  1. Determine the WWID:
    /lib/udev/scsi_id -gud /dev/sda
    "sda" is the local SCSI disk that you want to add to the blacklist.
    An example WWID is 360030057024d0730239134810c0cb833.
  2. Add the WWID to the "blacklist" stanza:
    blacklist {
            wwid   360030057024d0730239134810c0cb833
            devnode "^(ram|raw|loop|fd|md|dm-|sr|scd|st)[0-9]*"
            devnode "^hd[a-z]"
            devnode "^cciss.*"
Step 4: Customize multipath parameters for ONTAP LUNs
If your host is connected to LUNs from other vendors and any of the multipath parameter settings are overridden, you need to correct them by either modifying an existing stanza or adding a new stanza in the multipath.conf file that applies specifically to ONTAP LUNs. You need to scroll down in the file to review the changes that apply to your host. If you don't correct the parameters, the ONTAP LUNs might not work as expected.
Check your /etc/multipath.conf file, especially in the defaults section, for settings that might be overriding the default settings for multipath parameters.
Caution You shouldn't override the recommended parameter settings for ONTAP LUNs. These settings are required for optimal performance of your host configuration. Contact NetApp support, your OS vendor, or both for more information.
The following example shows how to correct an overridden default. In this example, the multipath.conf file defines values for path_checker and no_path_retry that aren't compatible with ONTAP LUNs, and you can't remove these parameters because ONTAP storage arrays are still attached to the host. Instead, you correct the values for path_checker and no_path_retry by adding a device stanza to the multipath.conf file that applies specifically to the ONTAP LUNs.
Show example
defaults {
   path_checker      readsector0
   no_path_retry     fail
devices {
   device {
      vendor          "NETAPP"
      product         "LUN"
      no_path_retry   queue
      path_checker    tur
Step 5: Review the known issues
There are no known issues.
