Learn about the Solaris Host Utilities SAN Toolkit for ONTAP storage
Solaris Host Utilities is a NetApp host software that provides a command line toolkit on your Oracle Solaris host. The toolkit is installed when you install the NetApp Host Utilities package. This kit provides the sanlun utility which helps you manage LUNs and host bus adapters (HBAs). The sanlun command returns information about the LUNs mapped to your host, multipathing, and information necessary to create initiator groups.
The following example output shows the ONTAP LUN information returned for the sanlun lun show command:
Show example output
#sanlun lun show all controller(7mode)/ device host lun vserver(Cmode) lun-pathname filename adapter protocol size mode ----------------------------------------------------------------------------------------------------------------------------------- data_vserver /vol/vol1/lun1 /dev/rdsk/c0t600A098038304437522B4E694E49792Dd0s2 qlc3 FCP 10g cDOT data_vserver /vol/vol0/lun2 /dev/rdsk/c0t600A098038304437522B4E694E497938d0s2 qlc3 FCP 10g cDOT data_vserver /vol/vol2/lun3 /dev/rdsk/c0t600A098038304437522B4E694E497939d0s2 qlc3 FCP 10g cDOT data_vserver /vol/vol3/lun4 /dev/rdsk/c0t600A098038304437522B4E694E497941d0s2 qlc3 FCP 10g cDOT
This toolkit is common across all Host Utilities configurations and protocols. As a result, all of the components don't apply to every configuration. Unused components don't affect your system performance. |
What's next
