Configure Veritas Infoscale 9 for FC, FCoE, and iSCSI with ONTAP storage
The Linux Host Utilities software provides management and diagnostic tools for Linux hosts that are connected to ONTAP storage. Use the Linux Host Utilities with Veritas Infoscale 9 for Oracle Linux (Red Hat Compatible Kernel based), Red Hat Enterprise Linux (RHEL), and SUSE Linux Enterprise Server hosts to support managing FC, FCoE, and iSCSI protocol operations with ONTAP LUNs.
Step 1: Optionally, enable SAN booting
You can configure your host to use SAN booting to simplify deployment and improve scalability.
Use the Interoperability Matrix Tool to verify that your Linux OS, host bus adapter (HBA), HBA firmware, HBA boot BIOS, and ONTAP version support SAN booting.
Refer to the Veritas Support Portal (Product Matrix, Platform Lookup, and HCL Matrix) to verify the SAN boot configuration support and known issues.
Enable SAN booting in the server BIOS for the ports to which the SAN boot LUN is mapped.
For information on how to enable the HBA BIOS, see your vendor-specific documentation.
Verify that the configuration was successful by rebooting the host and verifying that the OS is up and running.
Step 2: Install the Linux Host Utilities
NetApp strongly recommends installing the Linux Host Utilities to support ONTAP LUN management and assist technical support with gathering configuration data.
Installing the Linux Host Utilities doesn't change any host timeout settings on your Linux host. |
Step 3: Confirm the Veritas Dynamic Multipathing configuration for your host
Use Veritas Dynamic Multipathing (VxDMP) with Veritas Infoscale 9 to manage ONTAP LUNs.
To ensure that VxDMP is set up correctly for your host, you need to verify the VxDMP configuration and check the Array Support Library (ASL) and the Array Policy Module (APM) configuration. The ASL and APM packages for NetApp storage systems are installed during the Veritas software installation.
For heterogenous multipath environments, including Veritas Infoscale, Linux Native Device Mapper, and LVM volume manager, refer to the Veritas Product Administration documentation for the configuration settings. |
Ensure your configuration meets the system requirements. See the Interoperability Matrix Tool and the Veritas HCL Matrix.
Verify the ONTAP target array is attached to the VxDMP multipath:
vxdmpadmShow example
#vxdmpadm listenclosure ENCLR_NAME ENCLR_TYPE ENCLR_SNO STATUS ARRAY_TYPE LUN_COUNT FIRMWARE =================================================================================================== info_asa0 Info_ASA 81KDT+YTg35P CONNECTED ALUA 20 9161 infoscal1 Infoscal 81Ocq?Z7hPzC CONNECTED ALUA 23 9181 # vxdmpadm getdmpnode NAME STATE ENCLR-TYPE PATHS ENBL DSBL ENCLR-NAME =================================================================== infoscal1_22 ENABLED Infoscal 4 4 0 infoscal1
Check the configuration of the ASL and APM packages. NetApp recommends that you use the latest supported packages listed on the Veritas support portal.
Show example ASL and APM configuration
# vxdmpadm list dmpnode dmpnodename=infoscal1_22 | grep asl asl = libvxnetapp.so # vxddladm listversion |grep libvxnetapp.so libvxnetapp.so vm-8.0.0-rev-1 8.0 # rpm -qa |grep VRTSaslapm VRTSaslapm-9.0.3-RHEL9.x86_64 #vxddladm listsupport libname=libvxnetapp.so ATTR_NAME ATTR_VALUE ========================================= LIBNAME libvxnetapp.so VID NETAPP PID All ARRAY_TYPE ALUA, A/A
For optimum system configuration in storage failover operations, verify that you have the following Veritas VxDMP tunables:
Parameter Setting dmp_lun_retry_timeout
60
dmp_path_age
120
dmp_restore_interval
60
Set the DMP tunables to online:
# vxdmpadm settune dmp_tunable=value -
Verify that the tunables settings are correct:
# vxdmpadm gettuneThe following example shows the effective VxDMP tunables on a SAN host.
Show example
# vxdmpadm gettune Tunable Current Value Default Value dmp_cache_open on on dmp_daemon_count 10 10 dmp_delayq_interval 15 15 dmp_display_alua_states on on dmp_fast_recovery on on dmp_health_time 60 60 dmp_iostats_state enabled enabled dmp_log_level 1 1 dmp_low_impact_probe on on dmp_lun_retry_timeout 60 30 dmp_path_age 120 300 dmp_pathswitch_blks_shift 9 9 dmp_probe_idle_lun on on dmp_probe_threshold 5 5 dmp_restore_cycles 10 10 dmp_restore_interval 60 300 dmp_restore_policy check_disabled check_disabled dmp_restore_state enabled enabled dmp_retry_count 5 5 dmp_scsi_timeout 20 20 dmp_sfg_threshold 1 1 dmp_stat_interval 1 1 dmp_monitor_ownership on on dmp_monitor_fabric on on dmp_native_support off off
Configure the protocol timeout values:
FC/FCoEUse the default timeout values for FC and FCoE.
iSCSISet the
replacement_timeoutparameter value to 120.The iSCSI
replacement_timeoutparameter controls how long the iSCSI layer should wait for a timed-out path or session to reestablish itself before failing any commands on it. NetApp recommends setting the value ofreplacement_timeoutto 120 in the iSCSI configuration file.# grep replacement_timeout /etc/iscsi/iscsid.conf node.session.timeo.replacement_timeout = 120 -
Verify the parameter settings and path status for your ONTAP LUNs:
In AFF, FAS, or ASA configurations, a single ONTAP LUN should not require more than four paths. More than four paths can cause problems during a storage failure.
The following examples show the correct parameter settings and path status for ONTAP LUNs in an ASA, AFF, or FAS configuration.
ASA configurationAn ASA configuration optimizes all paths to a given LUN, keeping them active. This improves performance by serving I/O operations through all paths at the same time.
Show example
# vxdmpadm getsubpaths dmpnodename=infoscal1_21 NAME STATE[A] PATH-TYPE[M] CTLR-NAME ENCLR-TYPE ENCLR-NAME ATTRS PRIORITY =================================================================================== sdby ENABLED(A) Active/Optimized c1 Infoscal infoscal1 - - sddx ENABLED(A) Active/Optimized c2 Infoscal infoscal1 - - sdfe ENABLED(A) Active/Optimized c1 Infoscal infoscal1 - - sdfo ENABLED(A) Active/Optimized c2 Infoscal infoscal1 - -
AFF or FAS configurationAn AFF or FAS configuration should have two groups of paths with higher and lower priorities. Higher priority Active/Optimized paths are served by the controller where the aggregate is located. Lower priority paths are active but non-optimized because they are served by a different controller. Non-optimized paths are only used when optimized paths aren’t available.
The following example displays the output for an ONTAP LUN with two Active/Optimized paths and two Active/Non-Optimized paths:
Show example
# vxdmpadm getsubpaths dmpnodename-sfrac0_47 NAME STATE[A] PATH-TYPE[M] CTLR-NAME ENCLR-TYPE ENCLR-NAME ATTRS PRIORITY =================================================================================== sdas ENABLED Active/Non-Optimized c13 SFRAC sfrac0 - - sdb ENABLED(A) Active/Optimized c14 SFRAC sfrac0 - - sdcj ENABLED(A) Active/Optimized c14 SFRAC sfrac0 - - sdea ENABLED Active/Non-Optimized c14 SFRAC sfrac0 - -
Step 4: Known issues
There are no known issues.
