AIX Host Utilities 6.1 sample command reference
You can use the AIX Host Utilities 6.1 sample command reference for an end-to-end validation of the NetApp storage configuration using the host utilities tool.
List all host initiators mapped to host
You can retrieve a list of host initiators mapped to a host.
# sanlun fcp show adapter -v
Example output
bash-3.2# sanlun fcp show adapter -v adapter name: fcs0 WWPN: 100000109b22e143 WWNN: 200000109b22e143 driver name: /usr/lib/drivers/pci/emfcdd model: df1000e31410150 model description: FC Adapter serial number: YA50HY79S117 hardware version: Not Available driver version: 7.2.5.0 firmware version: 00012000040025700027 Number of ports: 1 port type: Fabric port state: Operational supported speed: 16 GBit/sec negotiated speed: Unknown OS device name: fcs0 adapter name: fcs1 WWPN: 100000109b22e144 WWNN: 200000109b22e144 driver name: /usr/lib/drivers/pci/emfcdd model: df1000e31410150 model description: FC Adapter serial number: YA50HY79S117 hardware version: Not Available driver version: 7.2.5.0 firmware version: 00012000040025700027 Number of ports: 1 port type: Fabric port state: Operational supported speed: 16 GBit/sec negotiated speed: Unknown OS device name: fcs1 bash-3.2#
List all LUNs mapped to host
You can retrieve a list of all LUNs mapped to a host.
# sanlun lun show -p -v all
Example output
ONTAP Path: vs_aix_clus:/vol/gpfs_205p2_207p1_vol_0_8/aix_205p2_207p1_lun LUN: 88 LUN Size: 15g Host Device: hdisk9 Mode: C Multipath Provider: AIX Native Multipathing Algorithm: round_robin host vserver AIX AIX MPIO path path MPIO host vserver path state type path adapter LIF priority ----------------------------------------------------- up primary path0 fcs0 fc_aix_1 1 up primary path1 fcs1 fc_aix_2 1 up secondary path2 fcs0 fc_aix_3 1 up secondary path3 fcs1 fc_aix_4 1
List all LUNs mapped to host from a given SVM
You can retrieve a list of all LUNs mapped to a host from a specified SVM.
# sanlun lun show -p -v sanboot_unix
Example output
ONTAP Path: sanboot_unix:/vol/aix_205p2_boot_0/boot_205p2_lun LUN: 0 LUN Size: 80.0g Host Device: hdisk85 Mode: C Multipath Provider: AIX Native Multipathing Algorithm: round_robin host vserver AIX AIX MPIO path path MPIO host vserver path state type path adapter LIF priority ------------------------------------------------- up primary path0 fcs0 sanboot_1 1 up primary path1 fcs1 sanboot_2 1 up secondary path2 fcs0 sanboot_3 1 up secondary path3 fcs1 sanboot_4 1
List all attributes of a given LUN mapped to host
You can retrieve a list of all attributes of a specified LUN mapped to a host.
# sanlun lun show -p -v vs_aix_clus:/vol/gpfs_205p2_207p1_vol_0_8/aix_205p2_207p1_lun
Example output
ONTAP Path: vs_aix_clus:/vol/gpfs_205p2_207p1_vol_0_8/aix_205p2_207p1_lun LUN: 88 LUN Size: 15g Host Device: hdisk9 Mode: C Multipath Provider: AIX Native Multipathing Algorithm: round_robin host vserver AIX AIX MPIO path path MPIO host vserver path state type path adapter LIF priority --------------------------------------------------------- up primary path0 fcs0 fc_aix_1 1 up primary path1 fcs1 fc_aix_2 1 up secondary path2 fcs0 fc_aix_3 1 up secondary path3 fcs1 fc_aix_4 1
List ONTAP LUN attributes by host device filename
You can retrieve a list of ONTAP LUN attributes by specifying a host device filename.
#sanlun lun show -d /dev/hdisk1
Example output
controller(7mode)/ device host lun vserver(Cmode) lun-pathname ----------------------------------------------------------------------------- vs_aix_clus /vol/gpfs_205p2_207p1_vol_0_0/aix_205p2_207p1_lun filename adapter protocol size mode ----------------------------------- hdisk1 fcs0 FCP 15g C
List all SVM target LIF WWPNs attached to host
You can retrieve a list of all SVM target LIF WWPNs attached to a host.
# sanlun lun show -wwpn
Example output
controller(7mode)/ target device host lun vserver(Cmode) wwpn lun-pathname -------------------------------------------------------------------------------- vs_aix_clus 203300a098ba7afe /vol/gpfs_205p2_207p1_vol_0_0/aix_205p2_207p1_lun vs_aix_clus 203300a098ba7afe /vol/gpfs_205p2_207p1_vol_0_9/aix_205p2_207p1_lun vs_aix_clus 203300a098ba7afe /vol/gpfs_205p2_207p1_vol_en_0_0/aix_205p2_207p1_lun_en vs_aix_clus 202f00a098ba7afe /vol/gpfs_205p2_207p1_vol_en_0_1/aix_205p2_207p1_lun_en filename adapter size mode ----------------------------------- hdisk1 fcs0 15g C hdisk10 fcs0 15g C hdisk11 fcs0 15g C hdisk12 fcs0 15g C
