Using SUSE Linux Enterprise Server 15 SP1 with NetApp ONTAP
Contributors netapp-sdaffy netapp-aherbin Download PDF of this page
Installing the Linux Unified Host Utilities
The NetApp Linux Unified Host Utilities software package is available on the NetApp Support Site in a 32-bit and 64-bit .rpm file. If you do not know which file is right for your configuration, use the NetApp Interoperability Matrix Tool to verify which one you need.
Installing the Linux Unified Host Utilities is strongly recommended, but not mandatory. The utilities do not change any settings on your Linux host. The utilities improve management and assist NetApp customer support in gathering information about your configuration.
Before you begin
If you have a version of Linux Unified Host Utilities currently installed you should upgrade it or, you should remove it and use the following steps to install the latest version.
  1. Download the 32-bit or 64-bit Linux Unified Host Utilities software package from the NetApp Support Site Site to your host.
  2. Use the following command to install the software package:
    rpm -ivh netapp_linux_unified_host_utilities-7-1.x86_64
SAN Toolkit
The toolkit is installed automatically when you install the NetApp Host Utilities package. This kit provides the sanlun utility, which helps you manage LUNs and HBAs. The sanlun command returns information about the LUNs mapped to your host, multipathing, and information necessary to create initiator groups.
Example
In the following example, the sanlun lun show command returns LUN information.
# sanlun lun show all
controller(7mode/E-Series)/            device     host               lun
vserver(cDOT/FlashRay)   lun-pathname  filename   adapter  protocol  size    Product
data_vserver          /vol/vol1/lun1   /dev/sdb   host16   FCP       120.0g  cDOT
data_vserver          /vol/vol1/lun1   /dev/sdc   host15   FCP       120.0g  cDOT
data_vserver          /vol/vol2/lun2   /dev/sdd   host16   FCP       120.0g  cDOT
data_vserver          /vol/vol2/lun2   /dev/sde   host15   FCP       120.0g  cDOT
SAN Booting
Before you begin
If you decide to use SAN booting, it must be supported by your configuration. You can use the NetApp Interoperability Matrix Tool to verify that your OS, HBA, HBA firmware and the HBA boot BIOS, and ONTAP version are supported.
Steps
  1. Map the SAN boot LUN to the host.
  2. Verify multiple paths are available.
    Remember, multiple paths will only be available after the host OS is up and running on the paths.
  3. Enable SAN booting in the server BIOS for the ports to which the SAN boot LUN is mapped.
    For information on how to enable the HBA BIOS, see your vendor-specific documentation.
  4. Reboot the host to verify the boot is successful.
Multipathing
For SUSE Linux Enterprise Server 15 SP1 the /etc/multipath.conf file must exist, but you do not need to make specific changes to the file. SUSE Linux Enterprise Server 15 SP1 is compiled with all settings required to recognize and correctly manage ONTAP LUNs.
You can use the multipath -ll command to verify the settings for your ONTAP LUNs.
The following sections provide sample multipath output for a LUN mapped to ASA and non-ASA personas.
All SAN Array Configuration
In All SAN Array (ASA) configurations, all paths to a given Logical Unit (LUN) are active and optimized. This means I/O can be served through all paths at the same time, thereby enabling better performance.
Example
The following example displays the correct output for an ONTAP LUN:
# multipath -ll
3600a0980383034466b2b4a3775474859 dm-3 NETAPP,LUN C-Mode
size=20G features='4 queue_if_no_path pg_init_retries 50 retain_attached_hw_handle' hwhandler='1 alua' wp=rw
|-+- policy='round-robin 0' prio=50 status=active
| |- 1:0:8:1  sdb 8:16 active ready running
| `- 2:0:8:1  sdd 8:48 active ready running
`-+- policy='round-robin 0' prio=10 status=enabled
  |- 1:0:9:1  sdc 8:32 active ready running
  `- 2:0:9:1  sde 8:64 active ready running
Do not use an excessive number of paths to a single LUN. No more than 4 paths should be required. More than 8 paths might cause path issues during storage failures.
Non-ASA Configuration
For non-ASA configuration there should be two groups of paths with different priorities. The paths with the higher priorities are Active/Optimized, meaning they are serviced by the controller where the aggregate is located. The paths with the lower priorities are active but are non-optimized because they are served from a different controller. The non-optimized paths are only used when no optimized paths are available.
Example
The following example displays the correct output for an ONTAP LUN with two Active/Optimized paths and two Active/Non-Optimized paths:
# multipath -ll
3600a09803831347657244e527766394e dm-5 NETAPP,LUN C-Mode
size=80G  features='3 queue_if_no_path pg_init_retries 50' hwhandler='1 alua' wp=rw
|-+- policy='service-time 0' prio=50 status=active
| |- 11:0:1:0 sdj 8:144 active ready running
| |- 11:0:2:0 sdr 65:16 active ready running
`-+- policy='service-time 0' prio=10 status=enabled
 |- 11:0:0:0 sdb 8:i6 active ready running
 |- 12:0:0:0 sdz 65:144 active ready running
SUSE Linux Enterprise Server 15 SP1 OS is compiled to recognize ONTAP LUNs and automatically set all configuration parameters correctly.
The multipath.conf file must exist for the multipath daemon to start, but you can create an empty, zero-byte file using the command:
touch /etc/multipath.conf
The first time you create this file, you might need to enable and start the multipath services.
# systemctl enable multipathd
# systemctl start multipathd
There is no requirement to add anything directly to multipath.conf file, unless you have devices that you do not want to be managed by multipath or you have existing settings that override defaults.
You can add the following syntax to the multipath.conf file to exclude the unwanted devices.
Replace the <DevId> with the WWID string of the device you want to exclude. Use the following command to determine the WWID:
blacklist {
        wwid <DevId>
        devnode "^(ram|raw|loop|fd|md|dm-|sr|scd|st)[0-9]*"
        devnode "^hd[a-z]"
        devnode "^cciss.*"
Example
In this example, sda is the local SCSI disk that we need to blacklist.
Steps
  1. Run the following command to determine the WWID:
    # /lib/udev/scsi_id -gud /dev/sda
    360030057024d0730239134810c0cb833
  2. Add this WWID to the blacklist stanza in the /etc/multipath.conf:
    blacklist {
         wwid   360030057024d0730239134810c0cb833
         devnode "^hd[a-z]"
         devnode "^cciss.*"
You should always check your /etc/multipath.conf file for legacy settings, especially in the defaults section, that may be overriding default settings.
The table below shows the critical multipathd parameters for ONTAP LUNs and the required values. If a host is connected to LUNs from other vendors and any of these parameters are overridden, they will need to be corrected by later stanzas in multipath.conf that apply specifically to ONTAP LUNs. If this is not done, the ONTAP LUNs may not work as expected. These defaults should only be overridden in consultation with NetApp and/or OS vendor and only when the impact is fully understood.
Parameter Setting
detect_prio
yes
dev_loss_tmo
"infinity"
failback
immediate
fast_io_fail_tmo
5
features
"2 pg_init_retries 50"
flush_on_last_del
"yes"
hardware_handler
"0"
no_path_retry
queue
path_checker
"tur"
path_grouping_policy
"group_by_prio"
path_selector
"service-time 0"
polling_interval
5
prio
"ontap"
product
LUN.*
retain_attached_hw_handler
yes
rr_weight
"uniform"
user_friendly_names
no
vendor
NETAPP
Example
The following example shows how to correct an overridden default. In this case, the multipath.conf file defines values for path_checker and no_path_retry that are not compatible with ONTAP LUNs. If they cannot be removed because of other SAN arrays still attached to the host, these parameters can be corrected specifically for ONTAP LUNs with a device stanza.
defaults {
   path_checker      readsector0
   no_path_retry      fail
devices {
   device {
      vendor         "NETAPP  "
      product         "LUN.*"
      no_path_retry     queue
      path_checker      tur
Known Problems and Limitations
NetApp Bug ID Title Description Bugzilla ID
1246622
Remote ports transit to a blocked state on SLES15SP1 with Emulex LPe12002 8GB FC during storage failover operations.
Remote ports transit to a blocked state on SLES15SP1 with Emulex LPe12002 8GB Fibre Channel (FC) during storage failover operations. When the storage node returns to an optimal state, the LIFs also come up and the remote port state should read "online." Occasionally, the remote port state might continue to read as "blocked” or "not present." This state can lead to a "failed faulty" path to LUNs at the multipath layer as well as an I/O outage for those LUNs. You can check the remoteport’s details against the following sample commands:
cat/sys/class/fc_host/host*/device/rport*/fc_remote_ports/rport*/port_name
cat/sys/class/fc_host/host*/device/rport*/fc_remote_ports/rport*/port_state
1139137
Release Notes
ASM Mirroring
ASM mirroring might require changes to the Linux multipath settings to allow ASM to recognize a problem and switch over to an alternate fail group. Most ASM configurations on ONTAP use external redundancy, which means that data protection is provided by the external array and ASM does not mirror data. Some sites use ASM with normal redundancy to provide two-way mirroring, normally across different sites. See Oracle Databases on ONTAP for further information.
