Troubleshoot Windows Host Utilities issues with ONTAP storage
Use the general troubleshooting techniques to investigate issues that might occur for a Windows Host Utilities with ONTAP storage configuration. You should also check the Windows Host Utilities Release Notes for known issues and solutions.
The following is a list of the different areas you can investigate for potential interoperability issues:
To identify potential interoperability issues, confirm that the Host Utilities support your combination of host operating system software, host hardware, ONTAP software, and storage system hardware. See the Interoperability Matrix Tool for more information.
Verify that you have the correct iSCSI configuration.
If iSCSI LUNs are not available after a reboot, verify that the target is listed as persistent on the Persistent Targets tab of the Microsoft iSCSI initiator GUI.
If applications using the LUNs display errors on startup, verify that the applications are configured to depend on the iSCSI service.
For FC paths to storage controllers running ONTAP, verify that the FC switches are zoned using the WWPNs of the target LIFs, not the WWPNs of the physical ports on the node.
Review the Release Notes for Windows Host Utilities to check for known issues. The Release Notes include a list of known issues and limitations.
Review the troubleshooting information in the ONTAP SAN administration documentation.
Search NetApp Bugs Online for recently discovered issues.
In the Bug Type field under Advanced Search, select iSCSI - Windows and then select Go. You should repeat the search for Bug Type FCP -Windows.
Collect information about your system.
Record any error messages that are displayed on the host or storage system console.
Collect the host and storage system log files.
Record the symptoms of the problem and any changes made to the host or storage system just before the problem appeared.
If you are unable to resolve the problem, contact NetApp technical support for assistance.
