Configure AIX for NVMe-oF with ONTAP storage
The IBM AIX and Virtual I/O Server (VIOS)/PowerVM hosts supports the NVMe/FC protocol with Asymmetric Namespace Access (ANA). ANA is equivalent to asymmetric logical unit access (ALUA) multipathing in iSCSI and FCP environments.
For additional details on supported configurations, see the Interoperability Matrix Tool (IMT).
You can use the following support and features with the NVMe-oF host configuration for AIX hosts. You should also review the known limitations before starting the configuration process.
Support available:
Beginning with ONTAP 9.13.1, NVMe/FC support is added for IBM AIX 7.2 TL5 SP6, AIX 7.3 TL1 SP2, and VIOS 3.1.4.21 with SAN boot support for both physical and virtual stacks. See the IBM documentation for more information on setting up SAN boot support.
NVMe/FC is supported with Power9 and Power10 IBM servers.
A separate PCM (Path Control Module), such as Host Utilities for AIX SCSI Multipath I/O (MPIO) support, isn't required for NVMe devices.
Virtualization support with NetApp (VIOS/PowerVM) is introduced with VIOS 3.1.4.21. This is only supported through NPIV (N_PortID Virtualization) storage virtualization mode using the Power10 IBM server.
Known limitations:
Qlogic/Marvel 32G FC HBAs on an AIX host doesn't support NVMe/FC.
SAN boot isn't supported for NVMe/FC devices using Power9 IBM server.
Verify that you have 32GB FC Emulex adapters (EN1A, EN1B, EN1L, EN1M) or 64GB FC adapters (EN1N, EN1P) with adapter firmware 12.4.257.30 and later versions.
If you have a MetroCluster configuration, NetApp recommends changing the AIX NVMe/FC default APD (All Path Down) time for supporting MetroCluster unplanned switchover events to avoid the AIX operating system enforcing a shorter I/O timeout. For additional information and the recommended changes to default settings, refer to NetApp Bugs Online - 1553249.
Depending on your AIX version, the Asymmetric Namespace Access Transition Timeout (ANATT) for the AIX host OS is 30 seconds or 60 seconds by default. If the ANATT default for your host is 30 seconds, you need to install an IBM Interim Fix (ifix) from the IBM website that sets the ANATT to 60 seconds to ensure that all ONTAP workflows are non-disruptive.
For NVMe/FC AIX support, you must install an ifix on the GA version of the AIX OS. The ifix isn't required for the VIOS/PowerVM OS.
You need to install the ifixes on an AIX version with no previously installed ifixes related to
devices.pciex.pciexclass.010802.rteon the system. Previously installed ifixes can conflict with the new installation.Set ANATT to 60 secondsThe default ANATT for the AIX level 72-TL5-SP6-2320 and AIX level 73-TL1-SP2-2320 releases is 30 seconds. IBM provides an ifix that sets the ANATT to 60 seconds. The ifix is available through IBM case ID TS018079082 and you can install it for the following AIX releases:
For AIX level 72-TL5-SP6-2320, install the
IJ46710s6a.230509.epkg.Zpackage. -
For AIX level 73-TL1-SP2-2320, install the
IJ46711s2a.230509.epkg.Zpackage.
Default ANATT is 60 secondsThe default ANATT is 60 seconds for the following AIX releases:
AIX level 73-TL2-SP3-2446
AIX level 73-TL2-SP2-2420
AIX level 72-TL5-SP8-2420
Optionally, set ANATT to 120 secondsIBM provides an ifix that sets the ANATT to 120 seconds. When you set the ANATT to 120 seconds, it enhances performance during ONTAP storage failover events. The ifix is available through IBM case ID TS012877410 and you can install it for the following AIX releases:
For AIX level 73-TL3-SP0-2446, install the
IJ53487s0a.250130.epkg.Zpackage. -
For AIX level 72-TL5-SP9-2446, install the
IJ53445s9a.250130.epkg.Zpackage.
The minimum server firmware version for Power9 servers for NVMe/FC support is FW 950.
The minimum server firmware version for Power10 servers for NVMe/FC support is FW 1010.
For more information on managing ifixes, see Managing Interim Fixes on AIX.
Step 1: Confirm the multipath configuration for your host
When you install the AIX OS, IBM MPIO used for NVMe multipathing is enabled by default.
Verify that NVMe multipathing is enabled:
lsmpio -l hdisk1Show example
name path_id status path_status parent connection hdisk1 8 Enabled Sel,Opt nvme12 fcnvme0, 9 hdisk1 9 Enabled Sel,Non nvme65 fcnvme1, 9 hdisk1 10 Enabled Sel,Opt nvme37 fcnvme1, 9 hdisk1 11 Enabled Sel,Non nvme60 fcnvme0, 9
Step 2: Configure NVMe/FC
You need to configure NVMe/FC for Broadcom/Emulex adapters on VIOS because the NVMe/FC protocol support is disabled in the Virtual Fibre Channel (vFC) on VIOS. The NVMe/FC protocol support is enabled in the physical FC by default.
Retrieve a list of virtual adapters:
lsmap -all -npivShow example
Name Physloc ClntID ClntName ClntOS ------------- ---------------------------------- ------ -------------- ------- vfchost0 U9105.22A.785DB61-V2-C2 4 s1022-iop-mcc- AIX Status:LOGGED_IN FC name:fcs4 FC loc code:U78DA.ND0.WZS01UY-P0-C7-T0 Ports logged in:3 Flags:0xea<LOGGED_IN,STRIP_MERGE,SCSI_CLIENT,NVME_CLIENT> VFC client name:fcs0 VFC client DRC:U9105.22A.785DB61-V4-C2
Enable support for the NVMe/FC protocol on an adapter by running the
ioscli vfcctrlcommand on the VIOS:vfcctrl -enable -protocol nvme -vadapter vfchost0Example outputThe "nvme" protocol for "vfchost0" is enabled.
Verify that the support has been enabled on the adapter:
lsattr -El vfchost0Show example
alt_site_wwpn WWPN to use - Only set after migration False current_wwpn 0 WWPN to use - Only set after migration False enable_nvme yes Enable or disable NVME protocol for NPIV True label User defined label True limit_intr false Limit NPIV Interrupt Sources True map_port fcs4 Physical FC Port False num_per_nvme 0 Number of NPIV NVME queues per range True num_per_range 0 Number of NPIV SCSI queues per range True
Enable the NVMe/Fc protocol for all adapters:
Change the
dflt_enabl_nvmeattribute value ofviosnpiv0pseudo device toyes. -
Set the
enable_nvmeattribute value toyesfor all the VFC host devices.chdev -l viosnpiv0 -a dflt_enabl_nvme=yeslsattr -El viosnpiv0Show example
bufs_per_cmd 10 NPIV Number of local bufs per cmd True dflt_enabl_nvme yes Default NVME Protocol setting for a new NPIV adapter True num_local_cmds 5 NPIV Number of local cmds per channel True num_per_nvme 8 NPIV Number of NVME queues per range True num_per_range 8 NPIV Number of SCSI queues per range True secure_va_info no NPIV Secure Virtual Adapter Information True
Enable the NVMe/Fc protocol for selected adapters by changing the
enable_nvmevalue of the VFC host device attribute toyes. -
Verify that
FC-NVMe Protocol Devicehas been created on the server:lsdev |grep fcnvmeExmaple outputfcnvme0 Available 00-00-02 FC-NVMe Protocol Device fcnvme1 Available 00-01-02 FC-NVMe Protocol Device
Record the host NQN from the server:
lsattr -El fcnvme0Show example
attach switch How this adapter is connected False autoconfig available Configuration State True host_nqn nqn.2014-08.org.nvmexpress:uuid:64e0xxxx-27d2-xxxx-858d-8a3xxxxc31e8 Host NQN (NVMe Qualified Name) True
lsattr -El fcnvme1Show example
Check the host NQN and verify that it matches the host NQN string for the corresponding subsystem on the ONTAP array:
vserver nvme subsystem host show -vserver vs_s922-55-lpar2Example outputVserver Subsystem Host NQN ------- --------- ---------------------------------------------------------- vs_s922-55-lpar2 subsystem_s922-55-lpar2 nqn.2014-08.org.nvmexpress:uuid:64e0xxxx-27d2-xxxx-858d-8a3xxxxc31e8
Verify that the initiator ports are up and running and you can see the target LIFs.
Step 3: Validate NVMe/FC
Verify that the ONTAP namespaces are correct for the NVMe/FC configuration.
Verify that the ONTAP namespaces correctly reflect on the host:
lsdev -Cc disk |grep NVMeExample outputhdisk1 Available 00-00-02 NVMe 4K Disk
Optionally, check the multipathing status:
Step 4: Review the known issues
The NVMe/FC host configuration for AIX with ONTAP storage has the following known issues:
| Burt ID | Title | Description |
AIX NVMe/FC default APD time to be modified for supporting MCC Unplanned Switchover events |
By default, AIX operating systems use an all path down (APD) timeout value of 20sec for NVMe/FC. However, ONTAP MetroCluster automatic unplanned switchover (AUSO) and TieBreaker initiated switchover workflows might take a little longer than the APD timeout window, causing I/O errors. |
AIX NVMe/FC caps ANATT at 60s, instead of 120s as advertised by ONTAP |
ONTAP advertises the ANA(asymmetric namespace access) transition timeout in controller identify at 120sec. Currently, with ifix, AIX reads the ANA transition timeout from controller identify, but effectively clamps it to 60sec if it is over that limit. |
AIX NVMe/FC hits EIO after ANATT expiry |
For any storage failover (SFO) events, if the ANA(asymmetric namespace access) transitioning exceeds the ANA transition timeout cap on a given path, the AIX NVMe/FC host fails with an I/O error despite having alternate healthy paths available to the namespace. |
AIX NVMe/FC waits for half/full ANATT to expire before resuming I/O after ANA AEN |
IBM AIX NVMe/FC does not support some Asynchronous notifications (AENs) that ONTAP publishes. This sub-optimal ANA handling will result in sub optimal performance during SFO operations. |
Step 5: Troubleshoot
Before troubleshooting any NVMe/FC failures, verify that you are running a configuration that is compliant with the IMT specifications. If you continue to have issues, contact NetApp support.
