Configure ESXi 8.x for NVMe-oF with ONTAP storage
You can configure NVMe over Fabrics (NVMe-oF) on initiator hosts running ESXi 8.x and ONTAP as the target.
Supportability
Beginning with ONTAP 9.16.1, space allocation is enabled by default for all newly created NVMe namespaces.
Beginning with ONTAP 9.9.1 P3, the NVMe/FC protocol is supported for ESXi 8.
Beginning with ONTAP 9.10.1, the NVMe/TCP protocol is supported for ONTAP.
Features
ESXi initiator hosts can run both NVMe/FC and FCP traffic through the same adapter ports. See the Hardware Universe for a list of supported FC adapters and controllers. See the NetApp Interoperability Matrix Tool for the most current list of supported configurations and versions.
For ESXi 8.0 and later releases, HPP (high performance plugin) is the default plugin for NVMe devices.
Known limitations
RDM mapping is not supported.
Enable NVMe/FC
NVMe/FC is enabled by default in vSphere releases.
You must check the ESXi host NQN string and verify that it matches with the host NQN string for the corresponding subsystem on the ONTAP array.
# esxcli nvme info get
Example output:
Host NQN: nqn.2014-08.org.nvmexpress:uuid:62a1xxxx-ba8c-xxxx-c954-000xxxx1a436
# vserver nvme subsystem host show -vserver nvme_fc
Example output:
Vserver Subsystem Host NQN ------- --------- ---------------------------------------------------------- nvme_fc nvme_ss nqn.2014-08.org.nvmexpress:uuid:62a1xxxx-ba8c-xxxx-c954-000xxxx1a436
If the host NQN strings do not match, you should use the vserver nvme subsystem host add command to update the correct host NQN string on your corresponding ONTAP NVMe subsystem.
Configure Broadcom/Emulex and Marvell/Qlogic
The lpfc driver and the qlnativefc driver in vSphere 8.x have the NVMe/FC capability enabled by default.
See Interoperability Matrix Tool to check whether the configuration is supported with the driver or firmware.
Validate NVMe/FC
You can use the following procedure to validate NVMe/FC.
Verify that the NVMe/FC adapter is listed on the ESXi host:
# esxcli nvme adapter list
Example output:
Adapter Adapter Qualified Name Transport Type Driver Associated Devices ------- ------------------------------- -------------- ---------- ------------------ vmhba64 aqn:lpfc:100000109b579f11 FC lpfc vmhba65 aqn:lpfc:100000109b579f12 FC lpfc vmhba66 aqn:qlnativefc:2100f4e9d456e286 FC qlnativefc vmhba67 aqn:qlnativefc:2100f4e9d456e287 FC qlnativefc
Verify that the NVMe/FC namespaces are correctly created:
The UUIDs in the following example represent the NVMe/FC namespace devices.
# esxcfg-mpath -b uuid.116cb7ed9e574a0faf35ac2ec115969d : NVMe Fibre Channel Disk (uuid.116cb7ed9e574a0faf35ac2ec115969d) vmhba64:C0:T0:L5 LUN:5 state:active fc Adapter: WWNN: 20:00:00:24:ff:7f:4a:50 WWPN: 21:00:00:24:ff:7f:4a:50 Target: WWNN: 20:04:d0:39:ea:3a:b2:1f WWPN: 20:05:d0:39:ea:3a:b2:1f vmhba64:C0:T1:L5 LUN:5 state:active fc Adapter: WWNN: 20:00:00:24:ff:7f:4a:50 WWPN: 21:00:00:24:ff:7f:4a:50 Target: WWNN: 20:04:d0:39:ea:3a:b2:1f WWPN: 20:07:d0:39:ea:3a:b2:1f vmhba65:C0:T1:L5 LUN:5 state:active fc Adapter: WWNN: 20:00:00:24:ff:7f:4a:51 WWPN: 21:00:00:24:ff:7f:4a:51 Target: WWNN: 20:04:d0:39:ea:3a:b2:1f WWPN: 20:08:d0:39:ea:3a:b2:1f vmhba65:C0:T0:L5 LUN:5 state:active fc Adapter: WWNN: 20:00:00:24:ff:7f:4a:51 WWPN: 21:00:00:24:ff:7f:4a:51 Target: WWNN: 20:04:d0:39:ea:3a:b2:1f WWPN: 20:06:d0:39:ea:3a:b2:1f
In ONTAP 9.7, the default block size for an NVMe/FC namespace is 4K. This default size is not compatible with ESXi. Therefore, when creating namespaces for ESXi, you must set the namespace block size as 512B. You can do this using the
vserver nvme namespace createcommand.Example,
vserver nvme namespace create -vserver vs_1 -path /vol/nsvol/namespace1 -size 100g -ostype vmware -block-size 512BRefer to the ONTAP 9 Command man pages for additional details.
Verify the status of the individual ANA paths of the respective NVMe/FC namespace devices:
# esxcli storage hpp path list -d uuid.df960bebb5a74a3eaaa1ae55e6b3411d fc.20000024ff7f4a50:21000024ff7f4a50-fc.2004d039ea3ab21f:2005d039ea3ab21f-uuid.df960bebb5a74a3eaaa1ae55e6b3411d Runtime Name: vmhba64:C0:T0:L3 Device: uuid.df960bebb5a74a3eaaa1ae55e6b3411d Device Display Name: NVMe Fibre Channel Disk (uuid.df960bebb5a74a3eaaa1ae55e6b3411d) Path State: active unoptimized Path Config: {ANA_GRP_id=4,ANA_GRP_state=ANO,health=UP} fc.20000024ff7f4a51:21000024ff7f4a51-fc.2004d039ea3ab21f:2008d039ea3ab21f-uuid.df960bebb5a74a3eaaa1ae55e6b3411d Runtime Name: vmhba65:C0:T1:L3 Device: uuid.df960bebb5a74a3eaaa1ae55e6b3411d Device Display Name: NVMe Fibre Channel Disk (uuid.df960bebb5a74a3eaaa1ae55e6b3411d) Path State: active Path Config: {ANA_GRP_id=4,ANA_GRP_state=AO,health=UP} fc.20000024ff7f4a51:21000024ff7f4a51-fc.2004d039ea3ab21f:2006d039ea3ab21f-uuid.df960bebb5a74a3eaaa1ae55e6b3411d Runtime Name: vmhba65:C0:T0:L3 Device: uuid.df960bebb5a74a3eaaa1ae55e6b3411d Device Display Name: NVMe Fibre Channel Disk (uuid.df960bebb5a74a3eaaa1ae55e6b3411d) Path State: active unoptimized Path Config: {ANA_GRP_id=4,ANA_GRP_state=ANO,health=UP} fc.20000024ff7f4a50:21000024ff7f4a50-fc.2004d039ea3ab21f:2007d039ea3ab21f-uuid.df960bebb5a74a3eaaa1ae55e6b3411d Runtime Name: vmhba64:C0:T1:L3 Device: uuid.df960bebb5a74a3eaaa1ae55e6b3411d Device Display Name: NVMe Fibre Channel Disk (uuid.df960bebb5a74a3eaaa1ae55e6b3411d) Path State: active Path Config: {ANA_GRP_id=4,ANA_GRP_state=AO,health=UP}
Configure NVMe/TCP
In ESXi 8.x, the required NVMe/TCP modules are loaded by default. To configure the network and the NVMe/TCP adapter, refer to the VMware vSphere documentation.
Validate NVMe/TCP
You can use the following procedure to validate NVMe/TCP.
Verify the status of the NVMe/TCP adapter:
Example output:
Adapter Adapter Qualified Name Transport Type Driver Associated Devices ------- ------------------------------- -------------- ------- ------------------ vmhba65 aqn:nvmetcp:ec-2a-72-0f-e2-30-T TCP nvmetcp vmnic0 vmhba66 aqn:nvmetcp:34-80-0d-30-d1-a0-T TCP nvmetcp vmnic2 vmhba67 aqn:nvmetcp:34-80-0d-30-d1-a1-T TCP nvmetcp vmnic3
Retrieve a list of NVMe/TCP connections:
esxcli nvme controller list
Example output:
Name Controller Number Adapter Transport Type Is Online Is VVOL --------------------------------------------------------------------------------------------------------- ----------------- ------- nqn.2014-08.org.nvmexpress.discovery#vmhba64#192.168.100.166:8009 256 vmhba64 TCP true false nqn.1992-08.com.netapp:sn.89bb1a28a89a11ed8a88d039ea263f93:subsystem.nvme_ss#vmhba64#192.168.100.165:4420 258 vmhba64 TCP true false nqn.1992-08.com.netapp:sn.89bb1a28a89a11ed8a88d039ea263f93:subsystem.nvme_ss#vmhba64#192.168.100.168:4420 259 vmhba64 TCP true false nqn.1992-08.com.netapp:sn.89bb1a28a89a11ed8a88d039ea263f93:subsystem.nvme_ss#vmhba64#192.168.100.166:4420 260 vmhba64 TCP true false nqn.2014-08.org.nvmexpress.discovery#vmhba64#192.168.100.165:8009 261 vmhba64 TCP true false nqn.2014-08.org.nvmexpress.discovery#vmhba65#192.168.100.155:8009 262 vmhba65 TCP true false nqn.1992-08.com.netapp:sn.89bb1a28a89a11ed8a88d039ea263f93:subsystem.nvme_ss#vmhba64#192.168.100.167:4420 264 vmhba64 TCP true false
Retrieve a list of the number of paths to an NVMe namespace:
esxcli storage hpp path list -d uuid.f4f14337c3ad4a639edf0e21de8b88bf
Example output:
tcp.vmnic2:34:80:0d:30:ca:e0-tcp.192.168.100.165:4420-uuid.f4f14337c3ad4a639edf0e21de8b88bf Runtime Name: vmhba64:C0:T0:L5 Device: uuid.f4f14337c3ad4a639edf0e21de8b88bf Device Display Name: NVMe TCP Disk (uuid.f4f14337c3ad4a639edf0e21de8b88bf) Path State: active Path Config: {ANA_GRP_id=6,ANA_GRP_state=AO,health=UP} tcp.vmnic2:34:80:0d:30:ca:e0-tcp.192.168.100.168:4420-uuid.f4f14337c3ad4a639edf0e21de8b88bf Runtime Name: vmhba64:C0:T3:L5 Device: uuid.f4f14337c3ad4a639edf0e21de8b88bf Device Display Name: NVMe TCP Disk (uuid.f4f14337c3ad4a639edf0e21de8b88bf) Path State: active unoptimized Path Config: {ANA_GRP_id=6,ANA_GRP_state=ANO,health=UP} tcp.vmnic2:34:80:0d:30:ca:e0-tcp.192.168.100.166:4420-uuid.f4f14337c3ad4a639edf0e21de8b88bf Runtime Name: vmhba64:C0:T2:L5 Device: uuid.f4f14337c3ad4a639edf0e21de8b88bf Device Display Name: NVMe TCP Disk (uuid.f4f14337c3ad4a639edf0e21de8b88bf) Path State: active unoptimized Path Config: {ANA_GRP_id=6,ANA_GRP_state=ANO,health=UP} tcp.vmnic2:34:80:0d:30:ca:e0-tcp.192.168.100.167:4420-uuid.f4f14337c3ad4a639edf0e21de8b88bf Runtime Name: vmhba64:C0:T1:L5 Device: uuid.f4f14337c3ad4a639edf0e21de8b88bf Device Display Name: NVMe TCP Disk (uuid.f4f14337c3ad4a639edf0e21de8b88bf) Path State: active Path Config: {ANA_GRP_id=6,ANA_GRP_state=AO,health=UP}
NVMe deallocate
The NVMe deallocate command is supported for ESXi 8.0u2 and later with ONTAP 9.16.1 and later.
Deallocate support is always enabled for NVMe namespaces. Deallocate also allows the guest OS to perform 'UNMAP' (sometimes called 'TRIM') operations on VMFS datastores. Deallocate operations allow a host to identify blocks of data that are no longer required because they no longer contain valid data. The storage system can then remove those data blocks so that the space can be consumed elsewhere.
On your ESXi host, verify the setting for DSM deallocate with TP4040 support:
esxcfg-advcfg -g /Scsi/NVmeUseDsmTp4040The expected value is 0.
Enable the setting for DSM deallocate with TP4040 support:
esxcfg-advcfg -s 1 /Scsi/NvmeUseDsmTp4040 -
Verify that the setting for DSM deallocate with TP4040 support is enabled:
esxcfg-advcfg -g /Scsi/NVmeUseDsmTp4040The expected value is 1.
For more information on NVMe deallocate in VMware vSphere, refer to Storage Space Reclamation in vSphere
Known issues
The NVMe-oF host configuration for ESXi 8.x with ONTAP has the following known issues:
| NetApp Bug ID | Title | Description |
ONTAP node non-operational when NVMe/FC protocol is used |
ONTAP 9.9.1 has introduced support for the NVMe "abort" command. When ONTAP receives the "abort" command to abort an NVMe |
I/O error occurs when Linux VMs using vNVMe adapters encounter a long all paths down (APD) window |
Linux VMs running vSphere 8.x and later and using virtual NVMe (vNVME) adapters encounter an I/O error because the |
