Configure RHEL 8.4 for NVMe-oF with ONTAP storage
Red Hat Enterpirse Linux (RHEL) hosts support the NVMe over Fibre Channel (NVMe/FC) and NVMe over TCP (NVMe/TCP) protocols with Asymmetric Namespace Access (ANA). ANA provides multipathing functionality equivalent to asymmetric logical unit access (ALUA) in iSCSI and FCP environments.
Learn how to configure NVMe over Fabrics (NVMe-oF) hosts for RHEL 8.4. For more support and feature information, see NVME-oF Overview.
NVMe-oF with RHEL 8.4 has the following known limitations:
SAN booting using the NVMe-oF protocol is not currently supported.
In-kernel NVMe multipath is disabled by default on NVMe-oF hosts in RHEL 8.4; you must enable it manually.
NVMe/TCP is available as a technology preview due to known issues.
Step 1: Optionally, enable SAN booting
You can configure your host to use SAN booting to simplify deployment and improve scalability. Use the Interoperability Matrix Tool to verify that your Linux OS, host bus adapter (HBA), HBA firmware, HBA boot BIOS, and ONTAP version support SAN booting.
Enable SAN booting in the server BIOS for the ports to which the SAN boot namespace is mapped.
For information on how to enable the HBA BIOS, see your vendor-specific documentation.
Reboot the host and verify that the OS is up and running.
Step 2: Verify the software version and NVMe configuration
Check that your system meets software requirements and verify NVMe package installations and host configuration.
Install RHEL 8.4 on the server. After the installation is complete, verify that you are running the required RHEL 8.4 kernel:
uname -rExample RHEL kernel version:
4.18.0-305.el8.x86_64
Install the
nvme-clipackage:rpm -qa|grep nvme-cliThe following example shows an nvme-cli package version:
nvme-cli-1.12-3.el8.x86_64
Install the
libnvmepackage:rpm -qa|grep libnvmeThe following example shows an libnvme package version:
libnvme-1.0-1.el8.x86_64
Enable in-kernel NVMe multipath:
grubby --args=nvme_core.multipath=Y --update-kernel /boot/vmlinuz-4.18.0-305.el8.x86_64 -
On the RHEL 8.4 host, check the hostnqn string at
/etc/nvme/hostnqn:cat /etc/nvme/hostnqnThe following example shows an hostnqn version:
nqn.2014-08.org.nvmexpress:uuid:9ed5b327-b9fc-4cf5-97b3-1b5d986345d1
Verify that the
hostnqnstring matches thehostnqnstring for the corresponding subsystem on the ONTAP array:::> vserver nvme subsystem host show -vserver vs_fcnvme_141Show example
Vserver Subsystem Host NQN ----------- --------------- ---------------------------------------------------------- vs_fcnvme_141 nvme_141_1 nqn.2014-08.org.nvmexpress:uuid:9ed5b327-b9fc-4cf5-97b3-1b5d986345d1
If the hostnqnstrings do not match, use thevserver modifycommand to update thehostnqnstring on your corresponding ONTAP array subsystem to match thehostnqnstring from/etc/nvme/hostnqnon the host. -
Reboot the host.
To run both NVMe and SCSI traffic on the same host, NetApp recommends using the in-kernel NVMe multipath for ONTAP namespaces and dm-multipath for ONTAP LUNs. To prevent dm-multipath from claiming ONTAP namespace devices, exclude them by adding the
enable_foreignsetting to the/etc/multipath.conffile:cat /etc/multipath.conf defaults { enable_foreign NONE } -
Restart the multipathd daemon by running a
systemctl restart multipathd.
Step 3: Configure the NVMe/FC or NVMe/TCP
Configure NVMe/FC with Broadcom/Emulex or Marvell/QLogic adapters, or configure NVMe/TCP using manual discovery and connect operations.
Configure NVMe/FC for a Broadcom/Emulex adapter.
Verify that you are using the supported adapter model:
Display the model names:
cat /sys/class/scsi_host/host*/modelnameYou should see output similar to:
LPe32002-M2 LPe32002-M2
Display the model descriptions:
cat /sys/class/scsi_host/host*/modeldescYou should see output similar to:
Emulex LightPulse LPe32002-M2 2-Port 32Gb Fibre Channel Adapter Emulex LightPulse LPe32002-M2 2-Port 32Gb Fibre Channel Adapter
Verify that you are using the recommended Broadcom
lpfcfirmware and inbox driver:-
Display the firmware version:
cat /sys/class/scsi_host/host*/fwrevThe command returns the firmware versions:
12.8.340.8, sli-4:2:c 12.8.340.8, sli-4:2:c
Display the inbox driver version:
cat /sys/module/lpfc/versionThe following example shows a driver version:
0:12.8.0.5
For the current list of supported adapter driver and firmware versions, see the Interoperability Matrix Tool.
Verify that the expected output of
lpfc_enable_fc4_typeis set to3:cat /sys/module/lpfc/parameters/lpfc_enable_fc4_type -
Verify that you can view your initiator ports:
cat /sys/class/fc_host/host*/port_nameYou should see output similar to:
0x100000109b1c1204 0x100000109b1c1205
Verify that your initiator ports are online:
cat /sys/class/fc_host/host*/port_stateYou should see the following output:
Online Online
Verify that the NVMe/FC initiator ports are enabled and that the target ports are visible:
cat /sys/class/scsi_host/host*/nvme_infoShow example
NVME Initiator Enabled XRI Dist lpfc0 Total 6144 IO 5894 ELS 250 NVME LPORT lpfc0 WWPN x100000109b1c1204 WWNN x200000109b1c1204 DID x011d00 ONLINE NVME RPORT WWPN x203800a098dfdd91 WWNN x203700a098dfdd91 DID x010c07 TARGET DISCSRVC ONLINE NVME RPORT WWPN x203900a098dfdd91 WWNN x203700a098dfdd91 DID x011507 TARGET DISCSRVC ONLINE NVME Statistics LS: Xmt 0000000f78 Cmpl 0000000f78 Abort 00000000 LS XMIT: Err 00000000 CMPL: xb 00000000 Err 00000000 Total FCP Cmpl 000000002fe29bba Issue 000000002fe29bc4 OutIO 000000000000000a abort 00001bc7 noxri 00000000 nondlp 00000000 qdepth 00000000 wqerr 00000000 err 00000000 FCP CMPL: xb 00001e15 Err 0000d906 NVME Initiator Enabled XRI Dist lpfc1 Total 6144 IO 5894 ELS 250 NVME LPORT lpfc1 WWPN x100000109b1c1205 WWNN x200000109b1c1205 DID x011900 ONLINE NVME RPORT WWPN x203d00a098dfdd91 WWNN x203700a098dfdd91 DID x010007 TARGET DISCSRVC ONLINE NVME RPORT WWPN x203a00a098dfdd91 WWNN x203700a098dfdd91 DID x012a07 TARGET DISCSRVC ONLINE NVME Statistics LS: Xmt 0000000fa8 Cmpl 0000000fa8 Abort 00000000 LS XMIT: Err 00000000 CMPL: xb 00000000 Err 00000000 Total FCP Cmpl 000000002e14f170 Issue 000000002e14f17a OutIO 000000000000000a abort 000016bb noxri 00000000 nondlp 00000000 qdepth 00000000 wqerr 00000000 err 00000000 FCP CMPL: xb 00001f50 Err 0000d9f8
Configure NVMe/FC for a Marvell/QLogic adapter.
Verify that you are using the supported adapter model, driver, and firmware versions:
cat /sys/class/fc_host/host*/symbolic_nameYou should see output similar to:
QLE2742 FW:v9.06.02 DVR:v10.02.00.104-k QLE2742 FW:v9.06.02 DVR:v10.02.00.104-k
Verify that
ql2xnvmeenableis set. This enables the Marvell adapter to function as an NVMe/FC initiator:cat /sys/module/qla2xxx/parameters/ql2xnvmeenableThe expected outptut is 1.
The NVMe/TCP protocol doesn't support the auto-connect operation. Instead, you can discover the NVMe/TCP subsystems and namespaces by performing the NVMe/TCP connect or connect-all operations manually.
Check that the initiator port can get the discovery log page data across the supported NVMe/TCP LIFs:
nvme discover -t tcp -w host-traddr -a traddrShow example
nvme discover -t tcp -w 192.168.1.8 -a 192.168.1.51 Discovery Log Number of Records 10, Generation counter 119 =====Discovery Log Entry 0====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 0 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.56e362e9bb4f11ebbaded039ea165abc:subsystem.nvme_118_tcp_1 traddr: 192.168.2.56 sectype: none =====Discovery Log Entry 1====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 1 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.56e362e9bb4f11ebbaded039ea165abc:subsystem.nvme_118_tcp_1 traddr: 192.168.1.51 sectype: none =====Discovery Log Entry 2====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 0 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.56e362e9bb4f11ebbaded039ea165abc:subsystem.nvme_118_tcp_2 traddr: 192.168.2.56 sectype: none
Verify that the other NVMe/TCP initiator-target LIF combinations can successfully fetch discovery log page data:
nvme discover -t tcp -w 192.168.1.8 -a 192.168.1.52 nvme discover -t tcp -w 192.168.2.9 -a 192.168.2.56 nvme discover -t tcp -w 192.168.2.9 -a 192.168.2.57
Run the
nvme connect-allcommand across all the supported NVMe/TCP initiator-target LIFs across the nodes:nvme connect-all -t tcp -w host-traddr -a traddr -1 1800Show example
nvme connect-all -t tcp -w 192.168.1.8 -a 192.168.1.51 -l 1800 nvme connect-all -t tcp -w 192.168.1.8 -a 192.168.1.52 -l 1800 nvme connect-all -t tcp -w 192.168.2.9 -a 192.168.2.56 -l 1800 nvme connect-all -t tcp -w 192.168.2.9 -a 192.168.2.57 -l 1800
Step 4: Optionally, enable 1MB I/O for NVMe/FC
ONTAP reports a Max Data Transfer Size (MDTS) of 8 in the Identify Controller data. This means the maximum I/O request size can be up to 1MB. To issue I/O requests of size 1MB for a Broadcom NVMe/FC host, you should increase the lpfc value of the lpfc_sg_seg_cnt parameter to 256 from the default value of 64.
These steps don't apply to Qlogic NVMe/FC hosts. |
Set the
lpfc_sg_seg_cntparameter to 256:cat /etc/modprobe.d/lpfc.confYou should see an output similar to the following example:
options lpfc lpfc_sg_seg_cnt=256
Run the
dracut -fcommand, and reboot the host. -
Verify that the value for
lpfc_sg_seg_cntis 256:cat /sys/module/lpfc/parameters/lpfc_sg_seg_cnt
Step 5: Validate NVMe-oF
Verify that the in-kernel NVMe multipath status, ANA status, and ONTAP namespaces are correct for the NVMe-oF configuration.
Verify that the in-kernel NVMe multipath is enabled:
cat /sys/module/nvme_core/parameters/multipathYou should see the following output:
Y
Verify that the appropriate NVMe-oF settings (such as, model set to NetApp ONTAP Controller and load balancing iopolicy set to round-robin) for the respective ONTAP namespaces correctly reflect on the host:
Display the subsystems:
cat /sys/class/nvme-subsystem/nvme-subsys*/modelYou should see the following output:
NetApp ONTAP Controller NetApp ONTAP Controller
Display the policy:
cat /sys/class/nvme-subsystem/nvme-subsys*/iopolicyYou should see the following output:
round-robin round-robin
Verify that the namespaces are created and correctly discovered on the host:
nvme listShow example
Node SN Model --------------------------------------------------------- /dev/nvme4n1 81Ix2BVuekWcAAAAAAAB NetApp ONTAP Controller Namespace Usage Format FW Rev ----------------------------------------------------------- 1 21.47 GB / 21.47 GB 4 KiB + 0 B FFFFFFFF
Verify that the controller state of each path is live and has the correct ANA status:
NVMe/FCnvme list-subsys /dev/nvme1n1Show example
nvme-subsys1 - NQN=nqn.1992-08.com.netapp:sn.04ba0732530911ea8e8300a098dfdd91:subsystem.nvme_145_1 \ +- nvme2 fc traddr=nn-0x208100a098dfdd91:pn-0x208200a098dfdd91 host_traddr=nn-0x200000109b579d5f:pn-0x100000109b579d5f live non-optimized +- nvme3 fc traddr=nn-0x208100a098dfdd91:pn-0x208500a098dfdd91 host_traddr=nn-0x200000109b579d5e:pn-0x100000109b579d5e live non-optimized +- nvme4 fc traddr=nn-0x208100a098dfdd91:pn-0x208400a098dfdd91 host_traddr=nn-0x200000109b579d5e:pn-0x100000109b579d5e live optimized +- nvme6 fc traddr=nn-0x208100a098dfdd91:pn-0x208300a098dfdd91 host_traddr=nn-0x200000109b579d5f:pn-0x100000109b579d5f live optimized
NVMe/TCPnvme list-subsys /dev/nvme0n1Show example
nvme-subsys0 - NQN=nqn.1992-08.com.netapp:sn.37ba7d9cbfba11eba35dd039ea165514:subsystem.nvme_114_tcp_1 \ +- nvme0 tcp traddr=192.168.2.36 trsvcid=4420 host_traddr=192.168.1.4 live optimized +- nvme1 tcp traddr=192.168.1.31 trsvcid=4420 host_traddr=192.168.1.4 live optimized +- nvme10 tcp traddr=192.168.2.37 trsvcid=4420 host_traddr=192.168.1.4 live non-optimized +- nvme11 tcp traddr=192.168.1.32 trsvcid=4420 host_traddr=192.168.1.4 live non-optimized +- nvme20 tcp traddr=192.168.2.36 trsvcid=4420 host_traddr=192.168.2.5 live optimized +- nvme21 tcp traddr=192.168.1.31 trsvcid=4420 host_traddr=192.168.2.5 live optimized +- nvme30 tcp traddr=192.168.2.37 trsvcid=4420 host_traddr=192.168.2.5 live non-optimized +- nvme31 tcp traddr=192.168.1.32 trsvcid=4420 host_traddr=192.168.2.5 live non-optimized
Verify that the NetApp plug-in displays the correct values for each ONTAP namespace device:
Columnnvme netapp ontapdevices -o columnShow example
Device Vserver Namespace Path --------- ------- -------------------------------------------------- /dev/nvme1n1 vserver_fcnvme_145 /vol/fcnvme_145_vol_1_0_0/fcnvme_145_ns NSID UUID Size ------- ------------------------------ -------------------- 1 23766b68-e261-444e-b378-2e84dbe0e5e1 85.90GB
JSONnvme netapp ontapdevices -o jsonShow example
{ "ONTAPdevices" : [ { "Device" : "/dev/nvme1n1", "Vserver" : "vserver_fcnvme_145", "Namespace_Path" : "/vol/fcnvme_145_vol_1_0_0/fcnvme_145_ns", "NSID" : 1, "UUID" : "23766b68-e261-444e-b378-2e84dbe0e5e1", "Size" : "85.90GB", "LBA_Data_Size" : 4096, "Namespace_Size" : 20971520 } ] }
Step 6: Review the known issues
There are no known issues.
