Configure RHEL 8.7 for NVMe-oF with ONTAP storage
Red Hat Enterpirse Linux (RHEL) hosts support the NVMe over Fibre Channel (NVMe/FC) and NVMe over TCP (NVMe/TCP) protocols with Asymmetric Namespace Access (ANA). ANA provides multipathing functionality equivalent to asymmetric logical unit access (ALUA) in iSCSI and FCP environments.
Learn how to configure NVMe over Fabrics (NVMe-oF) hosts for RHEL 8.7. For more support and feature information, see NVME-oF Overview.
NVMe-oF with RHEL 8.7 has the following known limitations:
SAN booting using the NVMe-oF protocol is not currently supported.
In-kernel NVMe multipath is disabled by default on NVMe-oF hosts in RHEL 8.7; you must enable it manually.
NVMe/TCP is available as a technology preview due to known issues.
Step 1: Optionally, enable SAN booting
You can configure your host to use SAN booting to simplify deployment and improve scalability. Use the Interoperability Matrix Tool to verify that your Linux OS, host bus adapter (HBA), HBA firmware, HBA boot BIOS, and ONTAP version support SAN booting.
Enable SAN booting in the server BIOS for the ports to which the SAN boot namespace is mapped.
For information on how to enable the HBA BIOS, see your vendor-specific documentation.
Reboot the host and verify that the OS is up and running.
Step 2: Verify the software version and NVMe configuration
Check that your system meets software requirements and verify NVMe package installations and host configuration.
Install RHEL 8.7 on the server. After the installation is complete, verify that you are running the required RHEL 8.7 kernel:
uname -rExample RHEL kernel version:
4.18.0-425.3.1.el8.x86_64
Install the
nvme-clipackage:rpm -qa|grep nvme-cliThe following example shows an nvme-cli package version:
nvme-cli-1.16-5.el8.x86_64
Install the
libnvmepackage:rpm -qa|grep libnvmeThe following example shows an libnvme package version:
libnvme-1.2-3.el8.x86_64
Enable in-kernel NVMe multipath:
grubby --args=nvme_core.multipath=Y --update-kernel /boot/vmlinuz-4.18.0-425.3.1.el8.x86_64 -
On the RHEL 8.7 host, check the
hostnqnstring at/etc/nvme/hostnqn:cat /etc/nvme/hostnqnThe following example shows an
hostnqnversion:nqn.2014-08.org.nvmexpress:uuid:a7f7a1d4-311a-11e8-b634-7ed30aef10b7
Verify that the
hostnqnstring matches thehostnqnstring for the corresponding subsystem on the ONTAP storage system:::> vserver nvme subsystem host show -vserver vs_nvme167Show example
Vserver Subsystem Host NQN ----------- --------------- ---------------------------------------------------------- vs_nvme167 rhel_167_LPe35002 nqn.2014-08.org.nvmexpress:uuid:a7f7a1d4-311a-11e8-b634-7ed30aef10b7
If the hostnqnstrings do not match, use thevserver modifycommand to update thehostnqnstring on your corresponding ONTAP storage system subsystem to match thehostnqnstring from/etc/nvme/hostnqnon the host. -
Reboot the host.
To run both NVMe and SCSI traffic on the same host, NetApp recommends using the in-kernel NVMe multipath for ONTAP namespaces and dm-multipath for ONTAP LUNs. To prevent dm-multipath from claiming ONTAP namespace devices, exclude them by adding the
enable_foreignsetting to the/etc/multipath.conffile:cat /etc/multipath.conf defaults { enable_foreign NONE } -
Restart the multipathd daemon by running a
systemctl restart multipathd.
Step 3: Configure NVMe/FC and NVMe/TCP
Configure NVMe/FC with Broadcom/Emulex or Marvell/QLogic adapters, or configure NVMe/TCP using manual discovery and connect operations.
Configure NVMe/FC for a Broadcom/Emulex adapter.
Verify that you are using the supported adapter model:
Display the model names:
cat /sys/class/scsi_host/host*/modelnameYou should see output similar to the following example:
LPe35002-M2 LPe35002-M2
Display the model descriptions:
cat /sys/class/scsi_host/host*/modeldescYou should see output similar to the following example:
Emulex LightPulse LPe35002-M2 2-Port 32Gb Fibre Channel Adapter Emulex LightPulse LPe35002-M2 2-Port 32Gb Fibre Channel Adapter
Verify that you are using the recommended Broadcom
lpfcfirmware and inbox driver:-
Display the firmware version:
cat /sys/class/scsi_host/host*/fwrevThe command returns the firmware versions:
14.0.505.12, sli-4:6:d 14.0.505.12, sli-4:6:d
Display the inbox driver version:
cat /sys/module/lpfc/versionThe following example shows a driver version:
0:14.0.0.15
For the current list of supported adapter driver and firmware versions, see the Interoperability Matrix Tool.
Verify that
lpfc_enable_fc4_typeis set to3:cat /sys/module/lpfc/parameters/lpfc_enable_fc4_type -
Verify that you can view your initiator ports:
cat /sys/class/fc_host/host*/port_nameYou should see output similar to the following example:
0x100000109b95467c 0x100000109b95467b
Verify that your initiator ports are online:
cat /sys/class/fc_host/host*/port_stateYou should see the following output:
Online Online
Verify that the NVMe/FC initiator ports are enabled and that the target ports are visible:
cat /sys/class/scsi_host/host*/nvme_infoShow example
NVME Initiator Enabled XRI Dist lpfc1 Total 6144 IO 5894 ELS 250 NVME LPORT lpfc1 WWPN x100000109b95467c WWNN x200000109b95467c DID x0a1500 ONLINE NVME RPORT WWPN x2071d039ea36a105 WWNN x206ed039ea36a105 DID x0a0907 TARGET DISCSRVC ONLINE NVME RPORT WWPN x2072d039ea36a105 WWNN x206ed039ea36a105 DID x0a0805 TARGET DISCSRVC ONLINE NVME Statistics LS: Xmt 00000001c7 Cmpl 00000001c7 Abort 00000000 LS XMIT: Err 00000000 CMPL: xb 00000000 Err 00000000 Total FCP Cmpl 0000000004909837 Issue 0000000004908cfc OutIO fffffffffffff4c5 abort 0000004a noxri 00000000 nondlp 00000458 qdepth 00000000 wqerr 00000000 err 00000000 FCP CMPL: xb 00000061 Err 00017f43 NVME Initiator Enabled XRI Dist lpfc0 Total 6144 IO 5894 ELS 250 NVME LPORT lpfc0 WWPN x100000109b95467b WWNN x200000109b95467b DID x0a1100 ONLINE NVME RPORT WWPN x2070d039ea36a105 WWNN x206ed039ea36a105 DID x0a1007 TARGET DISCSRVC ONLINE NVME RPORT WWPN x206fd039ea36a105 WWNN x206ed039ea36a105 DID x0a0c05 TARGET DISCSRVC ONLINE NVME Statistics LS: Xmt 00000001c7 Cmpl 00000001c7 Abort 00000000 LS XMIT: Err 00000000 CMPL: xb 00000000 Err 00000000 Total FCP Cmpl 0000000004909464 Issue 0000000004908531 OutIO fffffffffffff0cd abort 0000004f noxri 00000000 nondlp 00000361 qdepth 00000000 wqerr 00000000 err 00000000 FCP CMPL: xb 0000006b Err 00017f99
Configure NVMe/FC for a Marvell/QLogic adapter.
Verify that you are using the supported adapter driver and firmware versions:
cat /sys/class/fc_host/host*/symbolic_nameThe following example shows driver and firmware versions:
QLE2772 FW:v9.08.02 DVR:v10.02.07.400-k-debug QLE2772 FW:v9.08.02 DVR:v10.02.07.400-k-debug
Verify that
ql2xnvmeenableis set. This enables the Marvell adapter to function as an NVMe/FC initiator:cat /sys/module/qla2xxx/parameters/ql2xnvmeenableThe expected output is 1.
The NVMe/TCP protocol doesn't support the auto-connect operation. Instead, you can discover the NVMe/TCP subsystems and namespaces by performing the NVMe/TCP connect or connect-all operations manually.
Check that the initiator port can get the discovery log page data across the supported NVMe/TCP LIFs:
nvme discover -t tcp -w host-traddr -a traddrShow example
nvme discover -t tcp -w 192.168.211.5 -a 192.168.211.14 Discovery Log Number of Records 8, Generation counter 10 =====Discovery Log Entry 0====== trtype: tcp adrfam: ipv4 subtype: unrecognized treq: not specified portid: 0 trsvcid: 8009 subnqn: nqn.199208.com.netapp:sn.154a5833c78c11ecb069d039ea359e4b:discovery traddr: 192.168.211.15 sectype: none =====Discovery Log Entry 1====== trtype: tcp adrfam: ipv4 subtype: unrecognized treq: not specified portid: 1 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.154a5833c78c11ecb069d039ea359e4b:discovery traddr: 192.168.111.15 sectype: none =====Discovery Log Entry 2====== trtype: tcp adrfam: ipv4 subtype: unrecognized treq: not specified portid: 2 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.154a5833c78c11ecb069d039ea359e4b:discovery traddr: 192.168.211.14 sectype: none =====Discovery Log Entry 3====== trtype: tcp adrfam: ipv4 subtype: unrecognized treq: not specified portid: 3 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.154a5833c78c11ecb069d039ea359e4b:discovery traddr: 192.168.111.14 sectype: none =====Discovery Log Entry 4====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 0 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.154a5833c78c11ecb069d039ea359e4b:subsystem.rhel_tcp_165 traddr: 192.168.211.15 sectype: none =====Discovery Log Entry 5====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 1 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.154a5833c78c11ecb069d039ea359e4b:subsystem.rhel_tcp_165 traddr: 192.168.111.15 sectype: none =====Discovery Log Entry 6====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 2 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.154a5833c78c11ecb069d039ea359e4b:subsystem.rhel_tcp_165 traddr: 192.168.211.14 sectype: none =====Discovery Log Entry 7====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 3 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.154a5833c78c11ecb069d039ea359e4b:subsystem.rhel_tcp_165 traddr: 192.168.111.14 sectype: none [root@R650-13-79 ~]#
Verify that the other NVMe/TCP initiator-target LIF combinations can successfully fetch discovery log page data:
nvme discover -t tcp -w 192.168.211.5 -a 192.168.211.14 nvme discover -t tcp -w 192.168.211.5 -a 192.168.211.15 nvme discover -t tcp -w 192.168.111.5 -a 192.168.111.14 nvme discover -t tcp -w 192.168.111.5 -a 192.168.111.15
Run the
nvme connect-allcommand across all the supported NVMe/TCP initiator-target LIFs across the nodes:nvme connect-all -t tcp -w host-traddr -a traddr -1 1800Show example
nvme connect-all -t tcp -w 192.168.211.5-a 192.168.211.14 -l 1800 nvme connect-all -t tcp -w 192.168.211.5 -a 192.168.211.15 -l 1800 nvme connect-all -t tcp -w 192.168.111.5 -a 192.168.111.14 -l 1800 nvme connect-all -t tcp -w 192.168.111.5 -a 192.168.111.15 -l 1800
Step 4: Optionally, enable 1MB I/O for NVMe/FC
ONTAP reports a Max Data Transfer Size (MDTS) of 8 in the Identify Controller data. This means the maximum I/O request size can be up to 1MB. To issue I/O requests of size 1MB for a Broadcom NVMe/FC host, you should increase the lpfc value of the lpfc_sg_seg_cnt parameter to 256 from the default value of 64.
These steps don't apply to Qlogic NVMe/FC hosts. |
Set the
lpfc_sg_seg_cntparameter to 256:cat /etc/modprobe.d/lpfc.confYou should see an output similar to the following example:
options lpfc lpfc_sg_seg_cnt=256
Run the
dracut -fcommand, and reboot the host. -
Verify that the value for
lpfc_sg_seg_cntis 256:cat /sys/module/lpfc/parameters/lpfc_sg_seg_cnt
Step 5: Validate NVMe-oF
Verify that the in-kernel NVMe multipath status, ANA status, and ONTAP namespaces are correct for the NVMe-oF configuration.
Verify that the in-kernel NVMe multipath is enabled:
cat /sys/module/nvme_core/parameters/multipathYou should see the following output:
Y
Verify that the appropriate NVMe-oF settings (such as, model set to NetApp ONTAP Controller and load balancing iopolicy set to round-robin) for the respective ONTAP namespaces correctly reflect on the host:
Display the subsystems:
cat /sys/class/nvme-subsystem/nvme-subsys*/modelYou should see the following output:
NetApp ONTAP Controller NetApp ONTAP Controller
Display the policy:
cat /sys/class/nvme-subsystem/nvme-subsys*/iopolicyYou should see the following output:
round-robin round-robin
Verify that the namespaces are created and correctly discovered on the host:
nvme listShow example
Node SN Model --------------------------------------------------------- /dev/nvme4n1 81Ix2BVuekWcAAAAAAAB NetApp ONTAP Controller Namespace Usage Format FW Rev ----------------------------------------------------------- 1 21.47 GB / 21.47 GB 4 KiB + 0 B FFFFFFFF
Verify that the controller state of each path is live and has the correct ANA status:
nvme list-subsys /dev/nvme1n1Show example
nvme-subsys0 - NQN=nqn.1992-08.com.netapp:sn.154a5833c78c11ecb069d039ea359e4b:subsystem.rhel_tcp_165 \ +- nvme0 tcp traddr=192.168.211.15 trsvcid=4420 host_traddr=192.168.211.5 live non-optimized +- nvme1 tcp traddr=192.168.211.14 trsvcid=4420 host_traddr=192.168.211.5 live optimized +- nvme2 tcp traddr=192.168.111.15 trsvcid=4420 host_traddr=192.168.111.5 live non-optimized +- nvme3 tcp traddr=192.168.111.14 trsvcid=4420 host_traddr=192.168.111.5 live optimized
Verify that the NetApp plug-in displays the correct values for each ONTAP namespace device:
Columnnvme netapp ontapdevices -o columnShow example
Device Vserver Namespace Path --------- ------- -------------------------------------------------- /dev/nvme0n1 vs_tcp79 /vol/vol1/ns1 NSID UUID Size ---- ------------------------------ ------ 1 79c2c569-b7fa-42d5-b870-d9d6d7e5fa84 21.47GB
JSONnvme netapp ontapdevices -o jsonShow example
{ "ONTAPdevices" : [ { "Device" : "/dev/nvme0n1", "Vserver" : "vs_tcp79", "Namespace_Path" : "/vol/vol1/ns1", "NSID" : 1, "UUID" : "79c2c569-b7fa-42d5-b870-d9d6d7e5fa84", "Size" : "21.47GB", "LBA_Data_Size" : 4096, "Namespace_Size" : 5242880 }, ] }
Step 6: Review the known issues
These are the known issues:
| NetApp Bug ID | Title | Description |
RHEL 8.7 NVMe-oF hosts create duplicate persistent discovery controllers (PDCs) |
On NVMe-oF hosts, you can use the "nvme discover -p" command to create PDCs. When this command is used, only one PDC should be created per initiator-target combination. However, if you are running RHEL 8.8 on an NVMe-oF host, a duplicate PDC is created each time "nvme discover -p" is executed. This leads to unnecessary usage of resources on both the host and the target. |
