ONTAP support and features for Rocky Linux
Features supported for host configuration with NVMe over Fabrics (NVMe-oF) vary based on your version of ONTAP and Rocky Linux.
| Feature | Rocky Linux host version | ONTAP version |
Secure in-band authentication is supported over NVMe/TCP between a RHEL host and an ONTAP controller |
9.3 or later |
9.12.1 or later |
NVMe/TCP provides namespaces using the native |
8.2 or later |
9.10.1 or later |
NVMe/TCP is a fully supported enterprise feature |
9.0 or later |
9.10.1 or later |
NVMe and SCSI traffic is supported on the same host using NVMe multipath for NVMe-oF namespaces and dm-multipath for SCSI LUNs |
8.2 or later |
9.4 or later |
ONTAP supports the following SAN host features regardless of the ONTAP version running on your system setup.
Native NVMe multipathing is enabled by default |
10.0 or later |
SAN booting is enabled using the NVMe/FC protocol |
9.4 or later |
The |
8.2 or later |
The native udev rule in the |
8.2 or later |
For details on supported configurations, see the Interoperability Matrix Tool. |
What's next
| If your Rocky Linux version is .. | Learn about .. |
10 series |
9 series |
8 series |
