Configure Ubuntu 22.04 for NVMe-oF with ONTAP storage
NVMe over Fabrics (NVMe-oF), including NVMe over Fibre Channel (NVMe/FC) and other transports, is supported with Ubuntu 22.04 with Asymmetric Namespace Access (ANA). In NVMe-oF environments, ANA is the equivalent of ALUA multipathing in iSCSI and FC environments and is implemented with in-kernel NVMe multipath.
Learn how to configure NVMe over Fabrics (NVMe-oF) hosts for Ubuntu 22.04. For more support and feature information, see Ubuntu ONTAP support and features.
NVMe-oF with Ubuntu 22.04 has the following known limitations:
SAN booting using the NVMe-oF protocol is currently not supported for Ubuntu 22.04 with ONTAP.
For additional details on supported configurations, see the Interoperability Matrix Tool.
Step 1: Install Ubuntu and NVMe software and verify your configuration
To configure your host for NVMe-oF you need to install the host and NVMe software packages, enable multipathing, and verify your host NQN configuration.
Install Ubuntu 22.04 on the server. After the installation is complete, verify that you are running the specified Ubuntu 22.04 kernel:
# uname -rExample Ubuntu kernel version:
5.15.0-101-generic
Install the
nvme-clipackage:# apt list | grep nvmeThe following example shows an
nvme-clipackage version:nvme-cli/jammy-updates,now 1.16-3ubuntu0.1 amd64
On the Ubuntu 22.04 host, check the hostnqn string at
/etc/nvme/hostnqn:# cat /etc/nvme/hostnqnThe following example shows a
hostnqnvalue:nqn.2014-08.org.nvmexpress:uuid:063axxxx-438a-xxxx-b9b4-95axxxx6d041
On the ONTAP system, verify that the
hostnqnstring from/etc/nvme/hostnqnmatches thehostnqnstring for the corresponding subsystem on the ONTAP storage system:::> vserver nvme subsystem host show -vserver vs_106_fc_nvmeShow example
Vserver Subsystem Host NQN ----------- --------------- ---------------------------------------------------------- vs_106_fc_nvme ub_106 nqn.2014-08.org.nvmexpress:uuid:c047xxxx-e91e-xxxx-9995-ba4xxxx14631
If the hostnqnstrings do not match, use thevserver modifycommand to update thehostnqnstring on your corresponding ONTAP storage system subsystem to match thehostnqnstring from/etc/nvme/hostnqnon the host.
Step 2: Configure NVMe/FC and NVMe/TCP
Configure NVMe/FC for Broadcom/Emulex or Marvell/Qlogic adapters, or configure NVMe/TCP using manual discovery and connect operations.
Configure NVMe/FC for a Broadcom/Emulex adapter.
Verify that you are using the supported adapter model:
Display the model names:
cat /sys/class/scsi_host/host*/modelnameYou should see the following output:
LPe36002-M64 LPe36002-M64
Display the model descriptions:
cat /sys/class/scsi_host/host*/modeldescYou should see output similar to the following example:
Emulex LPe36002-M64 2-Port 64Gb Fibre Channel Adapter Emulex LPe36002-M64 2-Port 64Gb Fibre Channel Adapter
Verify that you are using the recommended Broadcom
lpfcfirmware and inbox driver.-
Display the firmware version:
cat /sys/class/scsi_host/host*/fwrevThe command returns the firmware versions:
14.2.673.40, sli-4:6:d 14.2.673.40, sli-4:6:d
Display the inbox driver version:
cat /sys/module/lpfc/versionThe following example shows a driver version:
0: 14.0.0.4
For the current list of supported adapter driver and firmware versions, see the Interoperability Matrix Tool.
Verify that
lpfc_enable_fc4_typeis set to3:cat /sys/module/lpfc/parameters/lpfc_enable_fc4_type -
Verify that you can view your initiator ports:
cat /sys/class/fc_host/host*/port_nameYou should see output similar to:
0x100000109bf0447c 0x100000109bf0447b
Verify that your initiator ports are online:
cat /sys/class/fc_host/host*/port_stateYou should see the following output:
Online Online
Verify that the NVMe/FC initiator ports are enabled and that the target ports are visible:
cat /sys/class/scsi_host/host*/nvme_infoShow example output
NVME Initiator Enabled XRI Dist lpfc1 Total 6144 IO 5894 ELS 250 NVME LPORT lpfc1 WWPN x100000109bf0447c WWNN x200000109bf0447c DID x022300 ONLINE NVME RPORT WWPN x200cd039eaa8138b WWNN x200ad039eaa8138b DID x021509 TARGET DISCSRVC ONLINE NVME RPORT WWPN x2010d039eaa8138b WWNN x200ad039eaa8138b DID x021108 TARGET DISCSRVC ONLINE NVME Statistics LS: Xmt 000000000e Cmpl 000000000e Abort 00000000 LS XMIT: Err 00000000 CMPL: xb 00000000 Err 00000000 Total FCP Cmpl 0000000000005238 Issue 000000000000523a OutIO 0000000000000002 abort 00000000 noxri 00000000 nondlp 00000000 qdepth 00000000 wqerr 00000000 err 00000000 FCP CMPL: xb 00000000 Err 00000000 NVME Initiator Enabled XRI Dist lpfc0 Total 6144 IO 5894 ELS 250 NVME LPORT lpfc0 WWPN x100000109bf0447b WWNN x200000109bf0447b DID x022600 ONLINE NVME RPORT WWPN x200bd039eaa8138b WWNN x200ad039eaa8138b DID x021409 TARGET DISCSRVC ONLINE NVME RPORT WWPN x200fd039eaa8138b WWNN x200ad039eaa8138b DID x021008 TARGET DISCSRVC ONLINE NVME Statistics LS: Xmt 000000000e Cmpl 000000000e Abort 00000000 LS XMIT: Err 00000000 CMPL: xb 00000000 Err 00000000 Total FCP Cmpl 000000000000523c Issue 000000000000523e OutIO 0000000000000002 abort 00000000 noxri 00000000 nondlp 00000000 qdepth 00000000 wqerr 00000000 err 00000000 FCP CMPL: xb 00000000 Err 00000000
The native inbox qla2xxx driver included in the Ubuntu 22.04 GA kernel has the latest upstream fixes. These fixes are essential for ONTAP support.
Configure NVMe/FC for a Marvell/QLogic adapter.
Verify that you are running the supported adapter driver and firmware versions:
# cat /sys/class/fc_host/host*/symbolic_nameThe following example shows driver and firmware versions:
QLE2872 FW: v9.14.02 DVR: v10.02.06.200-k QLE2872 FW: v9.14.02 DVR: v10.02.06.200-k
Verify that
ql2xnvmeenableis set. This enables the Marvell adapter to function as an NVMe/FC initiator:cat /sys/module/qla2xxx/parameters/ql2xnvmeenableThe expected output is 1.
NVMe/TCP does not have auto-connect functionality. Instead, you can discover the NVMe/TCP subsystems and namespaces by performing the NVMe/TCP connect or connect-all operations manually.
If a path goes down and is not reinstated within the default time out period of 10 minutes, NVMe/TCP cannot automatically reconnect. To prevent a time out, set the retry period for failover events to at least 30 minutes.
Check that the initiator port can fetch the discovery log page data across the supported NVMe/TCP LIFs:
nvme discover -t tcp -w host-traddr -a traddrShow example output
#nvme discover -t tcp -w 10.10.11.47-a 10.10.10.122 Discovery Log Number of Records 8, Generation counter 10 =====Discovery Log Entry 0====== trtype: tcp adrfam: ipv4 subtype: current discovery subsystem treq: not specified portid: 0 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.bbfb4ee8dfb611edbd07d039ea165590:discovery traddr: 10.10.10.122 eflags: explicit discovery connections, duplicate discovery information sectype: none =====Discovery Log Entry 1====== trtype: tcp adrfam: ipv4 subtype: current discovery subsystem treq: not specified portid: 1 trsvcid: 8009 subnqn: nqn.1992 08.com.netapp:sn.bbfb4ee8dfb611edbd07d039ea165590:discovery traddr: 10.10.10.124 eflags: explicit discovery connections, duplicate discovery information sectype: none =====Discovery Log Entry 2====== trtype: tcp
Verify that the other NVMe/TCP initiator-target LIF combinations are able to successfully fetch discovery log page data:
#nvme discover -t tcp -w 10.10.10.47 -a 10.10.10.122 #nvme discover -t tcp -w 10.10.10.47 -a 10.10.10.124 #nvme discover -t tcp -w 10.10.11.47 -a 10.10.11.122 #nvme discover -t tcp -w 10.10.11.47 -a 10.10.11.
Run the nvme connect-all command across all the supported NVMe/TCP initiator-target LIFs across the nodes, and set the controller loss timeout period for at least 30 minutes or 1800 seconds:
nvme connect-all -t tcp -w host-traddr -a traddr -l 1800Show example output
#nvme connect-all -t tcp -w 10.10.10.47 -a 10.10.10.122 -l 1800 #nvme connect-all -t tcp -w 10.10.10.47 -a 10.10.10.124 -l 1800 #nvme connect-all -t tcp -w 10.10.11.47 -a 10.10.11.122 -l 1800 #nvme connect-all -t tcp -w 10.10.11.47 -a 10.10.11.124 -l 1800
Step 3: Optionally, enable 1MB I/O for NVMe/FC
ONTAP reports a Max Data Transfer Size (MDTS) of 8 in the Identify Controller data. This means the maximum I/O request size can be up to 1MB. To issue I/O requests of size 1MB for a Broadcom NVMe/FC host, you should increase the lpfc value of the lpfc_sg_seg_cnt parameter to 256 from the default value of 64.
These steps don't apply to Qlogic NVMe/FC hosts. |
Set the
lpfc_sg_seg_cntparameter to 256:cat /etc/modprobe.d/lpfc.confYou should see an output similar to the following example:
options lpfc lpfc_sg_seg_cnt=256
Run the
dracut -fcommand, and reboot the host. -
Verify that the value for
lpfc_sg_seg_cntis 256:cat /sys/module/lpfc/parameters/lpfc_sg_seg_cnt
Step 4: Verify multipathing configuration
Verify that the in-kernel NVMe multipath status, ANA status, and ONTAP namespaces are correct for the NVMe-oF configuration.
Verify that the in-kernel NVMe multipath is enabled:
# cat /sys/module/nvme_core/parameters/multipathThe expected output is "Y".
Verify that the appropriate NVMe-oF settings (such as, model set to NetApp ONTAP Controller and load balancing iopolicy set to round-robin) for the respective ONTAP namespaces correctly reflect on the host:
# cat /sys/class/nvme-subsystem/nvme-subsys*/modelYou should see the following output:
NetApp ONTAP Controller NetApp ONTAP Controller
Display the policy:
# cat /sys/class/nvme-subsystem/nvme-subsys*/iopolicyYou should see the following output:
round-robin round-robin
Verify that the namespaces are created and correctly discovered on the host:
# nvme listShow example output
Node SN Model --------------------------------------------------------- /dev/nvme0n1 81CZ5BQuUNfGAAAAAAAB NetApp ONTAP Controller Namespace Usage Format FW Rev ----------------------------------------------------------- 1 21.47 GB / 21.47 GB 4 KiB + 0 B FFFFFFFF
Verify that the controller state of each path is live and has the correct ANA status:
NVMe/FC# nvme list-subsys /dev/nvme0n1Show example output
nvme-subsys4 - NQN=nqn.1992-08.com.netapp:sn.8763d311b2ac11ed950ed039ea951c46:subsystem. ub_106 \ +- nvme1 fc traddr=nn-0x20a6d039ea954d17:pn-0x20a7d039ea954d17,host_traddr=nn-0x200000109b1b95ef:pn-0x100000109b1b95ef live optimized +- nvme2 fc traddr=nn-0x20a6d039ea954d17:pn-0x20a8d039ea954d17,host_traddr=nn-0x200000109b1b95f0:pn-0x100000109b1b95f0 live optimized +- nvme3 fc traddr=nn-0x20a6d039ea954d17:pn-0x20aad039ea954d17,host_traddr=nn-0x200000109b1b95f0:pn-0x100000109b1b95f0 live non-optimized +- nvme5 fc traddr=nn-0x20a6d039ea954d17:pn-0x20a9d039ea954d17,host_traddr=nn-0x200000109b1b95ef:pn-0x100000109b1b95ef live non-optimized
NVMe/TCP# nvme list-subsys /dev/nvme1n1Show example output
nvme-subsys1 - NQN=nqn.1992- 08.com.netapp:sn. bbfb4ee8dfb611edbd07d039ea165590:subsystem.rhel_tcp_95 +- nvme1 tcp traddr=10.10.10.122,trsvcid=4420,host_traddr=10.10.10.47,src_addr=10.10.10.47 live +- nvme2 tcp traddr=10.10.10.124,trsvcid=4420,host_traddr=10.10.10.47,src_addr=10.10.10.47 live +- nvme3 tcp traddr=10.10.11.122,trsvcid=4420,host_traddr=10.10.11.47,src_addr=10.10.11.47 live +- nvme4 tcp traddr=10.10.11.124,trsvcid=4420,host_traddr=10.10.11.47,src_addr=10.10.11.47 live
Verify that the NetApp plug-in displays the correct values for each ONTAP namespace device:
Column# nvme netapp ontapdevices -o columnShow example output
Device Vserver Namespace Path ----------------------- ------------------------------ /dev/nvme0n1 co_iscsi_tcp_ubuntu /vol/vol1/ns1 NSID UUID Size ------------------------------------------------------------ 1 79c2c569-b7fa-42d5-b870-d9d6d7e5fa84 21.47GB
JSON# nvme netapp ontapdevices -o jsonShow example output
{ "ONTAPdevices" : [ { "Device" : "/dev/nvme0n1", "Vserver" : "co_iscsi_tcp_ubuntu", "Namespace_Path" : "/vol/nvmevol1/ns1", "NSID" : 1, "UUID" : "79c2c569-b7fa-42d5-b870-d9d6d7e5fa84", "Size" : "21.47GB", "LBA_Data_Size" : 4096, "Namespace_Size" : 5242880 }, ] }
Step 5: Review the known issues
The NVMe-oF host configuration for Ubuntu 22.04 with ONTAP release has the following known issue:
| NetApp Bug ID | Title | Description |
CONTAPEXT-2037 |
Ubuntu 22.04 NVMe-oF hosts create duplicate Persistent Discovery Controllers |
On NVMe-oF hosts, you can use the "nvme discover -p" command to create Persistent Discovery Controllers (PDCs). This command should only create one PDC for each initiator-target combination. However, if you are running Ubuntu 22.04 on an NVMe-oF host, a duplicate PDC is created each time "nvme discover -p" is executed. This leads to unnecessary usage of resources on both the host and the target. |
