NIS window
Contributors netapp-ivanad
The NIS window enables you to view the current NIS settings for your storage system.
Command buttons
  • Create
    Opens the Create NIS Domain dialog box, which enables you to create NIS domains.
  • Edit
    Opens the Edit NIS Domain dialog box, which enables you to add, delete, or modify NIS servers.
  • Delete
    Deletes the selected NIS domain.
  • Refresh
    Updates the information in the window.
