QoS Policy Groups window
Contributors netapp-ivanad
Storage QoS (Quality of Service) can help you manage risks related to meeting your performance objectives. Storage QoS enables you to limit the throughput of workloads and to monitor workload performance. You can use the QoS Policy groups window to manage your policy groups and view information about them.
Command buttons
  • Create
    Opens the Create QoS Policy Group dialog box, which enables you to create new policy groups.
  • Edit
    Opens the Edit QoS Policy Group dialog box, which enables you to modify the selected policy group.
  • Delete
    Deletes the selected policy groups.
  • Refresh
    Updates the information in the window.
QoS Policy Groups list
The QoS Policy Groups list displays the policy group name and the maximum throughput for each policy group.
  • Name
    Displays the name of the QoS policy group.
  • Minimum Throughput
    Displays the minimum throughput limit specified for the policy group.
    If you have not specified any minimum throughput value, the system automatically displays “None” as the value and this value is case-sensitive.
  • Maximum Throughput
    Displays the maximum throughput limit specified for the policy group.
    If you have not specified any maximum throughput value, the system automatically displays “Unlimited” as the value and this value is case-sensitive.
  • Storage Objects Count
    Displays the number of storage objects assigned to the policy group.
Details area
The area below the QoS Policy Groups list displays detailed information about the selected policy group.
  • Assigned Storage Objects tab
    Displays the name and type of the storage object that is assigned to the selected policy group.
