Create intercluster LIFs
Contributors NetAppZacharyWambold netapp-ivanad
Creating intercluster logical interfaces (LIFs) enables the cluster network to communicate with a node. You must create an intercluster LIF within each IPspace that will be used for peering, on each node in each cluster for which you want to create a peer relationship.
Steps
  1. Click Configuration > Advanced Cluster Setup.
  2. In the Setup Advanced Cluster Features window, click Proceed next to the Cluster Peering option.
  3. Select an IPspace from the IPspace list.
  4. Enter the IP address, port, network mask, and gateway details of each node.
  5. Click Submit and Continue.
What to do next
You should enter the cluster details in the Cluster Peering window to continue with cluster peering.
