Deleting active LDAP clients
Contributors netapp-ivanad
You can use System Manager to delete an active LDAP client when you do not want a storage virtual machine (SVM) to be associated with it.
Steps
  1. Click Storage > SVMs.
  2. Select the SVM, and then click SVM Settings.
  3. Click the SVM Settings tab.
  4. In the Services pane, click LDAP Configuration.
  5. Click Delete.
  6. Select the confirmation check box, and then click Delete.
