Deleting the BranchCache configuration
Contributors netapp-ivanad
You can use System Manager to delete the BranchCache configuration if you no longer want to offer caching services on the storage virtual machine (SVM) that is configured for BranchCache.
Steps
  1. Click Storage > SVMs.
  2. Select the SVM, and then click SVM Settings.
  3. In the BranchCache tab, click Delete.
  4. Select the confirmation check box, and then click Delete.
    You can also remove existing hashes from the hash store.
