Enabling or disabling efficiency policies
Contributors netapp-ivanad
You can use System Manager to enable or disable an efficiency policy.
Steps
  1. Click Storage > SVMs.
  2. Select the SVM, and then click SVM Settings.
  3. In the Policies pane, click Efficiency Policies.
  4. Select one or more efficiency policies that you want to enable or disable.
  5. Click Status > Enable or Status > Disable, as required.
  6. If you are disabling an efficiency policy, select the confirmation check box, and then click OK.
