Provisioning storage by creating a FabricPool-enabled aggregate manually
Contributors netapp-ivanad
You can use System Manager to create a FabricPool-enabled aggregate to attach a cloud tier to the SSD aggregate.
Before you begin
  • You must have created a cloud tier and attached it to the cluster in which the SSD aggregate resides.
  • An on-premises cloud tier must have been created.
  • A dedicated network connection must exist between the cloud tier and the aggregate.
About this task
The following object stores can be used as cloud tiers:
  • StorageGRID
  • Alibaba Cloud (Starting with System Manager 9.6)
  • Amazon Web Services (AWS) Simple Storage Service (S3)
  • Amazon Web Services (AWS) Commercial Cloud Service (C2S)
  • Microsoft Azure Blob storage
  • IBM Cloud
  • Google Cloud
Note
  • Azure Stack, which is an on-premises Azure services, is not supported.
  • If you want to use any object store as a cloud tier, other than StorageGRID, you must have the FabricPool capacity license.
Steps
  1. Create a FabricPool-enabled aggregate by using one of the following methods:
    • Click Applications & Tiers > Storage Tiers > Add Aggregate.
    • Click Storage > Aggregate & Disks > Aggregates > Create.
  2. Enable the Manually Create Aggregate option to create an aggregate.
  3. Create a FabricPool-enabled aggregate:
    1. Specify the name of the aggregate, the disk type, and the number of disks or partitions to include in the aggregate.
      Note
      Only all flash (all SSD) aggregates support FabricPool-enabled aggregates.
      The minimum hot spare rule is applied to the disk group that has the largest disk size.
    2. Modify the RAID configuration of the aggregate:
      1. Click Change.
      2. In the Change RAID Configuration dialog box, specify the RAID type and the RAID group size.
        Shared disks support two RAID types: RAID-DP and RAID-TEC.
      3. Click Save.
  4. Select the FabricPool checkbox, and then select a cloud tier from the list.
  5. Click Create.
