Provision a datastore and create its containing LUN and volume
PDF of this doc site
Provision NAS storage
Provision SAN storage
Data protection and disaster recovery
Creating your file...
A datastore contains virtual machines and their VMDKs on the ESXi host. The datastore on the ESXi host is provisioned on a LUN on the storage cluster.
Virtual Storage Console for VMware vSphere (VSC) must be installed and registered with the vCenter Server that manages the ESXi host.
VSC must have sufficient cluster or storage virtual machine (SVM) credentials to create the LUN and volume.
VSC automates the datastore provisioning, including creating a LUN and volume on the specified SVM.
From the vSphere Web Client Home page, click Hosts and Clusters.
In the navigation pane, expand the datacenter where you want to provision the datastore.
Right-click the ESXi host, and then select NetApp VSC > Provision Datastore.
Alternatively, you can right-click the cluster when provisioning to make the datastore available to all hosts in the cluster.
Provide the required information in the wizard:
Select VMFS as the datastore type.
Select FC/FCoE as the VMFS protocol.
Select None as the Storage Capability Profile.
Select the box for Thin provision.
Select the Create new volume check box.
