Set the iSCSI replacement timeout value
To support multipathing, you must modify the replacement timeout value in the iSCSI configuration file.
Step
Change the replacement timeout value in the
/etc/iscsi/iscsid.conffile from the default of 120 to 5.The replacement timeout value looks like the following in
iscsid.conf:node.session.timeo.replacement_timeout = 5
