The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
Verify that the iSCSI service is running on an existing SVM
PDF of this doc site
Provision NAS storage
Provision SAN storage
Data protection and disaster recovery
Creating your file...
Your file is ready
If you choose to use an existing storage virtual machine (SVM), you must verify that the iSCSI service is running on the SVM.
Before you begin
You must have selected an existing SVM on which you plan to create a new LUN.
Steps
Navigate to the SVMs window.
Click the SVM Settings tab.
In the Protocols pane, click iSCSI.
Verify that the iSCSI service is running.
Record the iSCSI interfaces listed for the SVM.
What to do next
If the iSCSI service is not running, start the iSCSI service or create a new SVM.
If there are fewer than two iSCSI interfaces per node, update the iSCSI configuration on the SVM or create a new SVM for iSCSI.
