System Manager Classic
Determining which ports can be used for a broadcast domain (ONTAP 9.7 and earlier)
Contributors netapp-barbe
Before you can configure a broadcast domain to add to the new IPspace, you must determine what ports are available for the broadcast domain.
Note This task is relevant for ONTAP 9.0 - 9.7, not ONTAP 9.8.
Before you begin
You must be a cluster administrator to perform this task.
About this task
  • Ports can be physical ports, VLANs, or interface groups (ifgroups).
  • The ports that you want to add to the new broadcast domain cannot be assigned to an existing broadcast domain.
  • If the ports that you want to add to the broadcast domain are already in another broadcast domain (for example, the Default broadcast domain in the Default IPspace), you must remove the ports from that broadcast domain before assigning them to the new broadcast domain.
  • Ports that have LIFs assigned to them cannot be removed from a broadcast domain.
  • Because the cluster management and node management LIFs are assigned to the Default broadcast domain in the Default IPspace, the ports assigned to these LIFs cannot be removed from the Default broadcast domain.
Steps
  1. Determine the current port assignments.
    network port show
    Node   Port IPspace  Broadcast Domain Link   MTU  Admin/Oper
    node1
           e0a  Cluster  Cluster          up    9000  auto/1000
           e0b  Cluster  Cluster          up    9000  auto/1000
           e0c  Default  Default          up    1500  auto/1000
           e0d  Default  Default          up    1500  auto/1000
           e0e  Default  Default          up    1500  auto/1000
           e0f  Default  Default          up    1500  auto/1000
           e0g  Default  Default          up    1500  auto/1000
    node2
    In this example, the output from the command provides the following information:
    • Ports e0c, e0d, e0e, e0f, and e0g on each node are assigned to the Default broadcast domain.
    • These ports are potentially available to use in the broadcast domain of the IPspace that you want to create.
  2. Determine which ports in the Default broadcast domain are assigned to LIF interfaces, and therefore cannot be moved to a new broadcast domain.
    network interface show
             Logical      Status     Network         Current   Current Is
    Vserver  Interface    Admin/Oper Address/Mask    Node      Port    Home
    Cluster
             node1_clus1  up/up       10.0.2.40/24   node1     e0a     true
             node1_clus2  up/up       10.0.2.41/24   node1     e0b     true
             node2_clus1  up/up       10.0.2.42/24   node2     e0a     true
             node2_clus2  up/up       10.0.2.43/24   node2     e0b     true
    cluster1
             cluster_mgmt up/up       10.0.1.41/24   node1     e0c     true
             node1_mgmt   up/up       10.0.1.42/24   node1     e0c     true
             node2_mgmt   up/up       10.0.1.43/24   node2     e0c     true
    In the following example, the output from the command provides the following information:
    • The node ports are assigned to port e0c on each node and the cluster administrative LIF's home node is on e0c on node1.
    • Ports e0d, e0e, e0f, and e0g on each node are not hosting LIFs and can be removed from the Default broadcast domain and then added to a new broadcast domain for the new IPspace.
